MSIAfterburner
Changes:
- Active bus clock monitoring for Intel CPUs. Previous version measured Intel bclk just once on startup, so if you use software CPU overclocking via adjusting bus clock on the fly, wrong CPU clock speed could be displayed. Now bus clock is measured on each hardware polling period.
-Added OverdriveN X2 overclocking API support for 17.7.2 AMD display drivers.
- Unofficial overclocking API is currently broken in 17.7.2. drivers (applying the clocks with it makes GPU stuck in lowest P-state till reboot) so MSI Afterburner is forcibly disabling unofficial overclocking mode and always using official ADL overclocking codepath on 17.7.2 and newer drivers. However, unofficial overclocking mode can still be manually unlocked via configuration file on 17.7.2 and newer drivers if AMD decide to provide a fix for unofficial overclocking mode in the future.
Alexey Nicolaychuk aka Unwinder, RivaTuner creator
Changes:
...ขอบใจจ้า
