MSI Afterburner 4.4.0 Beta 11 gets OSD hardware monitoring graphs
อย่าว่างั้น-งี้ เลยนะครับ
ผมไปหาโหลดโดยตรง มาจากเว็บของ MSI เลย
มันได้ version: MSIAfterburnerSetup440Beta10
https://www.msi.com/page/afterburner
แต่ของ guru3d เป็น version: MSIAfterburnerSetup440Beta11
http://www.guru3d.com/files-get/msi-...wnload,32.html
ของ guru3d ใหม่กว่าเว็บ MSI เลยเหรอครับ
We just updated MSI Afterburner 4.4.0 to Beta build 12. This new update adds labels for OSD graphs. The new build also includes an updated RTSS statistics server RTSS 7.0.0 beta 26....
We just updated MSI Afterburner 4.4.0 to Beta build 12. This new update adds labels for OSD graphs. The new build also includes an updated RTSS Guru3D statistics server RTSS 7.0.0 beta 26.
MSI Afterburner 4.4.0 beta 12:
Added labels for OSD graphs
Changed default hardware monitoring graphs order. GPU related graphs have been reodered a bit in order to provide more convenient layout on multi-GPU systems. ?Framerate? and ?Frametime? graphs have been moved to the bottom of the list
Now you may hold <Shift> key when clicking a checkmark next to a graph name in the list of active hardware monitoring graphs to enable or disable all graphs at once
Graph colors and text size tags are now defined by OSD layout and can be customized there if necessary
RTSS 7.0.0 beta 26 is included in distributive:
New reusable Vulkan vertex buffer implementation no longer limits the On-Screen Display geometry by 16K vertices
Fixed vertex buffer overflow in Direct3D8 and Direct3D9 raster 3D On-Screen Display rendering implementations causing the text to disappear when trying to display around 700 or more characters
Please keep in mind that these are betas, and such be dealt with as such.
