น่าสนไหมครับ http://www.computeandmore.com/productlist.php?id=6483
รายละเอียดสินค้า:
Graphics Processing
GeForce? GTX 1060
Core Clock
Boost: 1860 MHz / Base: 1632 MHz in OC mode
Boost: 1835 MHz / Base: 1607 MHz in Gaming mode
(Reference Card Boost: 1708 MHz/ Base: 1506MHz)
Process Technology
16 nm
Memory Clock
9026 MHz
Memory Size
6 GB
Memory Type
GDDR5
Memory Bus
192 bit
Card Bus
PCI-E 3.0 x 16
Output
Dual-link DVI-D *1
HDMI-2.0b*1 (Max Resolution: 4096x2160 @60 Hz)
Display Port-1.4 *3 (Max Resolution: 7680x4320 @60 Hz)
Digital max resolution
7680x4320
Multi-view
4
Card size
H=38 L=280 W=111 mm
PCB Form
ATX
DirectX
DirectX 12 API feature level 12_1
OpenGL
4.5
Recommended PSU
400W
Power Connectors
8 pin*1
Price: 12,800 Baht
รายละเอียดสินค้า:
Graphics Processing
GeForce? GTX 1060
Core Clock
Process Technology
16 nm
Memory Clock
9026 MHz
Memory Size
6 GB
Memory Type
GDDR5
Memory Bus
192 bit
Card Bus
PCI-E 3.0 x 16
Output
Dual-link DVI-D *1
7680x4320
Multi-view
4
Card size
H=38 L=280 W=111 mm
PCB Form
ATX
DirectX
OpenGL
4.5
Recommended PSU
400W
Power Connectors
8 pin*1
Price: 12,800 Baht
