Radeon Software Crimson Edition 16.8.1 จ้า ๆ
  • Radeon Software Crimson Edition 16.8.1 จ้า ๆ
    Radeon Software Crimson Edition 16.8.1 Highlights
    Support for:
    Radeon RX 470 Graphics
    Radeon RX 460 Graphics
    New AMD Crossfire profile available for:
    F1 2016
    Fixed Issues
    Max memory overclock available on Radeon RX 480 being too low in Radeon WattMan has been resolved.
    Overwatch? may experience an application crash on some Radeon? RX 480 configurations when using AMD Crossfire technology mode.
    The Division poor Crossfire scaling may be experienced in some low resolution configurations when using AMD Crossfire technology mode.
    DOTA2? may experience lower than expected performance when in AMD Crossfire mode.
    Radeon Settings may not report the correct Vulkan? driver or API version information.
    Firefox? may experience an application crash when hardware acceleration is enabled for content playback.
    Low frame rate or stutter may be experienced Wolfenstein?: The Old Blood? on Radeon? RX 480.
    Updating drivers through Radeon Settings may sometimes fail with an error message.
    Known Issues
    A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay".
    Ark Survival Evolved? may experience an error message when trying to launch the game in some configurations.
    DOTA2? may experience an application hang when using the Vulkan? API and changing resolution or game/quality settings.
    Corruption may be experienced in Rise of the Tomb Raider using the DirectX?12 API on some Hybrid Graphics configurations when performing a task switch.
    Shader Cache may remain be enabled when set to "off" in Radeon Settings on some Hybrid Graphics configurations.
    Radeon RX 480 graphics may experience intermittent stuttering in The Division? when high game settings are used and vsync is enabled.
    Battlefield? 4 may experience intermittent crashes when using Mantle. As a work around users are suggested to switch to DirectX?11.
    Radeon Pro Duo may experience a black screen in Total War?: Warhammer with the games API set to DirectX?12 and V-Sync enabled.
    World of Tanks? may experience stuttering after performing a task switch in AMD Crossfire mode.
    Rocket League? may experience flickering when in AMD Crossfire mode.
    Ashes of the Singularity? may experience an application crash with "crazy" in game settings and Multi-GPU enabled.
    เพิ่งลงเลย ยังไม่ได้เทส
    ก่อนนี้หลังลง Windows 10 Anniversary Update เล่นดอทเปิด VSync บางทีมันล๊อคที่ 30 เฉยเลย แถม alt+tab ออกเกมไม่ได้
    ไม่รู้แก้อันนี้รึเปล่า
    Edit: แก้ๆ สรุปปัญหาเกิดจาก Vulkan 5555 โหลดมาเฉยๆยังไม่ได้ใส่ Option ให้มันรันก็ทำเกมเอ๋อได้ด้วย
    Edit2: ไม่หายวุ้ย ขึ้นๆลงๆ งงเลย = =
