AMD RADEON TECHNOLOGY - POLARIS-VEGA RADEON RX400 Red Zone Club
  • POWERCOLOR RED DEVIL RX 480 8GB GDDR5: 269 USD, available July 29th โอ้ เวร กว่าจะเข้าไทย ทำไรกันอยู่ amddddddd
    A NEW Devil is BORN
    With its restless desire to rule the universe without seeing any light; Devil 13, the ruler of the underworld, created a new Devil to rise from the underworld and master all creatures.
    Red Devil as he was named , known to be the only Devil besides his creator to master all elements of the Hexagon. Controlling Fire, Lightning, Air, Magic Energy, Dark Soul, and Mirage, its presence was feared by all corners of the new world.
    Ever since, no one dared to challenge Devil?s true gaming empire.
    Taipei, Taiwan ? July 21st, 2016 ? TUL Corporation, a leading and innovative manufacturer of AMD graphic cards since 1997, has released a brand new video card in PowerColor Red Devil RX 480 8GB GDDR5. It is based on AMD?s latest GCN 4 architecture designed for GloFo 14nm FinFET that delivers premium VR capability, increased level of performance, smooth VR, seamless support for next-gen gaming monitors, and CPU-free game streaming or recording. Furthermore, the model also supports AMD?s newest technologies such as Direct 12? and VulkanTM, FreeSyncTM, and Liquid VR.
    PowerColor Red Devil RX 480 8GB GDDR5 utilizes 8GB of GDDR5 memory with 2304 stream processors, ships core clock up to 1330MHz, and has 2000MHz memory clock speed which is connected via a new high speed 256-bit memory interface. Having a 8Pin power connector plus superior 6+1 multi-phases where each phase supplies 25W instead of 22.5W found in other boards this board is designed for the ultimate performance.
    The board design enhances the power efficiency and stability, and also enables ultimate performance in overclocking mode with BIOS switch. In order to achieve better thermal solution in both ultra overclocking and silent overclocking mode, PowerColor Red Devil RX 480 adopts the newest fan technology called Double Blade III which increases airflows and prevents dust deposition on fans. The Double Blade III is made with triple 80mm 2-ball bearing fans, with 2pcs of 8mm and another 2pcs of 6mm nickel-plated heat pipe for the best heat dissipation.
    In creating one solid card with all components, the Red Devil also includes a backplate as well as having the PCB locked in a thermal module using the method of spring screws to pin through the rivets. The backplate and the copper based thermal module hold the GPU for not only balancing the pressure of the whole board but also for avoiding the damage done to the GPU and other components if dropped.
    Graphic Engine Radeon RX 480
    Stream Processor 2304 (36CUs)
    Video Memory 8GB GDDR5
    Engine Clock Up to 1330MHz with boost
    Memory Clock 2000MHz x 4 (8.0Gbps)
    Memory Interface 256bit
    Manufacturing Process GloFo 14nm FinFET
    Architecture GCN 4
    DirectX Support 12
    BUS Standard PCIE 3.0
    Standard Display Connectors DVI-D/HDMI/DPx3
    Extension Power Connector 1*8Pin PCIE Power Connector
    Credit
    • Originally posted by บิว View Post
      ลองเอาคะแนนมาเทียบกันดูครับ
      การ์ดตัวเดียว OC ไปที่ 1320-1355
      การ์ด 2 ตัว ไม่ OC
      รบกวนหน่อยครับอยากรู้ว่าได้แต้มประมาณนี้แปลว่า fx-8320 ยังดัน RX 480 CF ได้อยู่ในโหมด DX12 ใช่ไหมครับ
      ได้ บางเกมส์ก็ชิว เจอเกมส์อย่างARMA3 ก็ไม่ชิว เป็นเกมส์ๆไป แต่โดยรวมถ้า@4.5GHz+ ชิวได้ทุกเกมส์
      • Originally posted by MooNoiOCZ View Post
        ขอบคุณครับ ตอนนี้ผมก็ 4.5GHz อยู่
        ถ้ามันดัน RX480 CF ได้อยู่จะได้ไม่ต้องเปลี่ยน
          ดันได้ครับ แต่อยากบอกว่า ถ้าเปลี่ยนตอนเล่นเกมส์fps. มันได้ขึ้นมาอีกเยอะเลยครับ
          ท่านชอบเล่นเกมส์แนวไหน บอกรายชื่อเกมส์มาหน่อยครับ
            ตอนนี้เล่น dark soul 3 เกมเดียวครับ
            เกมต่อไปคง GTA V, witcher 3 อีกหลายเกมแนวนี้ครับ
              ไม่ต้องอัพครับ รอZEN มาค่อยอัพครับ
              เพราะท่านOC 4.5GHz สบายๆ
              • เห็นแบบนี้คงใช้ FX OC 4.5GHz ยาวๆละ
                • sappphire rx480 nitro+ มาไทยเมื่อไหร่ ทราบมั้ยครับ
                  • เล่นปรับไม่แคร์ nvidia game works เลยแหะ
                    ปรับสุดกิน VRAM เกิน 4GB
                    • Originally posted by O_ho View Post
                      คงดัน fx 8320 ผม 4.4 ขึ้นมาอีกหน่อยจาก 4.3
                      ดูเฟรมแล้วเป็นที่น่าพอใจตกไม่ต่ำกว่าสี่สิบ รอปีหน้าไม่ zen ก็ทิดอิน ค่อยอัพทีเดียว
                      • FX 8 มาอยู่กระทู้นี้หลายคนเลย 555
                        การเล่นเกมสื oc แช่ไว้ 4.5
                        แต่เวลาเล่นเน้ตทั่วๆๆไป ปิดเทอโบคอร์ ตลอดทุกสถานะ เปิด คุลควิทแทนนะครับ แต่ถ้าเล่นเกมส์เข้าไบออสก็ปิดคูลควิทแทน เหลือ แต่ oc ค้างไว้ 4.5 GHZ
                        คุณภาพเมนบอร้ดก็ส่งผลต่อประสิทธิภาพ FX 8 เช่นกันกัน บางท่าน 970 ไฟ 4+1 เรฟใหม่ๆๆดุว่ามี เฟรมดรอปบ้างรึเปล่า เคยเจอในบอร้ดเก่าๆๆเฟสน้อยๆๆน่ะ
                        8 เทรดตั้งแต่ปี 2012 ตอนนี้ ปี 2016 ก็ไม่รู้ว่าหลายเกมส์ที่ว่าจะดึงเทรดมาได้ถึง 6 หรือเป่านั่นแหละปัญหาคอขวดที่เกิด
                        ที่เห้นดึง ครบ 8 ก็ ACU ที่ท่านข้าวรีวิว i7 เจน 4 นี่มีหนาวๆๆเลย
                        ส่วนการ์ดแสบไฟ ไนโตร ตามที่ได้ข้อมูลมา คล้อกแค่ 100 นี่พลังขึ้นปริ้ดเลย สุดหลอด RX 480 ข่าวว่าไม่เกิน 1.6 GHZ นะครับคงต้องซิ้งค์เทพๆๆหน่อย
                        • ไป ได้ ยัน 2.0 GHZ เลยคับ แต่ๆๆๆๆๆๆๆ มันจะไปไหวหรือป่าว ตัว non ref เฟสไฟ ซิ้งระบายความร้อนไหวป่าว คงต้องรอดูกันต่อไปว่าจะไปได้สักเท่าไร
                          • ้เข้าไปในกลุ่ม bitcoin ไปเจอรูปนี้เข้า ถ้าเป็นของจริงไม่แปลกใจเลยว่าทำไมหาซื้อยาก
                            • สงสัยรอ non ref. ไม่ไหวเล่นโมไบออสกันเลย
                              • จอง 480 ตัวราคา 8980 กับเดว่าไปเมื่อกี้ เขาบอกเหลือแต่ตัว RX 480 ref แบบ OC ตัวธรรมดาต้องรอไปก่อน มันต่างกันมากมั้ยครับ เพิ่มเงินอีก 1000 ได้เลย กับรอตัวธรรมดา แบบความแรงมันคุ้มเงินที่เพิ่มไปหรือเปล่าครับ
