พอดี จะถอยสักตัวนึง
เอามา CrossFire มันจะวิ่ง x 16 เต็มแรงป่าว
รายละเอียด
CPU
Supports Intelฎ Core 2 Quad/Core 2 Duo based processors in LGA775 package.
Supports Intelฎ Yorkfield, Wolfdale.
Supports FSB 1333/1066/800 MHz.
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
Intelฎ P35 Chipset
- Supports FSB 800/1066/1333MHz.
- Supports dual channel, DDR2 667/800/1066 (OC).
Intelฎ ICH9R Chipset- Hi-Speed USB (USB2.0) controller, 480Mb/sec, up to 12 ports.
- 4 SATAII with 2 eSATA ports with transfer rate up to 3Gb/s.
- PCI Master v2.3, I/O APIC.
- ACPI 2.0 compliant.
- Serial ATA RAID 0/1/5/10.
- Integrated AHCI controller.
e-SATA functionality would be fully supported by VISTA ( In Box driver with AHCI driver);
Under WinXP e-SATA functionality would not be fully supported without AHCI driver.
Main Memory
Supports four unbuffered DIMM of 1.8 Volt DDR2 SDRAM
Supports up to 8GB memory size.
Supports dual channel DDR2 memory architecture.
Supports DDR2 667/800/1066 (OC) memory interface.
Slots
Two PCI Express 16X slots with 1x16 and 1x4 operations (PCI Express Bus SPEC V1.0a compliant; supports CrossFire Technology)
Two PCI Express x1 slots. (support PCI Express Bus specification v1.0a compliant)
Two 32-bit PCI v2.3 master PCI bus slots.
- Support 3.3v/5v PCI bus interface.
On-Board IDE/SATA
One Ultra DMA 66/100/133 IDE controller integrated in Marvellฎ 88SE6111.
- Supports PIO, Bus Master operation modes.
- Can connect up to two Ultra ATA drives.
SATAII controller integrated in ICH9R and Marvellฎ 88SE6111 chipest
- Up to 300MB/sec transfer speed.
- Supports four SATAII ports and two eSATA ports by ICH9R.
- Supports one SATAII port by 88SE6111.
Audio
Chip integrated by Realtekฎ ALC888/ALC888T
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 spec.
- Meet Microsoft Vista Premium spec.
- Supports VoIP Card. (only for ALC888T)
LAN
Supports PCI Express LAN 10/100/1000 Fast Ethernet by Realtek 8111B.
IEEE1394
VIAฎ VT6308 chipset
- Supports up to two 1394 ports. (Rear panel x1, pinheader x1)
- Transfer rate is up to 400Mbps.
Internal I/O Connectors
- ATX 24-Pin power connector
- ATX 4-pin VGA power connector
- 8-pin ATX 12V power connector
- CPU / System x 5 FAN connectors
- CD-in connector
- Front panel audio connector
- Front panel connector
- 1 x SPDIF-out pinheader
- 1 x chasis intrusion connector
- 1 x serial port pinheader
- 3 x USB 2.0 connectors
- 1 x Floppy disk drive connector
- 5 x Serial ATAII connectors
- 1 x ATA133 connector
- 1 x IEEE1394 connector support additional 1 port (optional)
- 2 x H/W OC pinheaders (optional)
รายละเอียด
CPU
Chipset
Intelฎ P35 Chipset
Main Memory
Slots
On-Board IDE/SATA
Audio
LAN
IEEE1394
VIAฎ VT6308 chipset
- CD-in connector
