Drivers + Support
AMD Radeon Software Crimson Edition 16.4.1
Article Number: RN-WIN-RADEONCRIMSON16.4.1
Radeon Software Crimson Edition is AMD's revolutionary new graphics software that delivers redesigned functionality, supercharged graphics performance, remarkable new features, and innovation that redefines the overall user experience. Every Radeon Software release strives to deliver new features, better performance and stability improvements.
Radeon Software Crimson Edition 16.4.1 Highlights
Support for:
Quantum Break
Upto 35% faster performance using Quantum Break on Radeon R9 Fury X than with Radeon Software Crimson Edition 16.3.2(1).
Oculus Rift
HTC Vive
Resolved Issues
Frame rate capping issues experienced in some DirectX 12 applications is resolved.
Hitman may experience flickering when played in DirectX 11 mode using high game shadow settings.
Known Issues
A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay"
Need For Speed may experience poor scaling or flickering in AMD Crossfire mode. As a work around users can disable the profile through the Radeon Settings game manager.
The Division may experience flickering in AMD Crossfire mode.
Power efficiency toggle in Radeon Settings is showing up for some unsupported products.
XCOM2 users may experience an application crash when using AMD Crossfire mode. As a work around please disable AMD Crossfire for the games profile in the Radeon Settings Gaming tab.
Some DX9 applications cannot disable AMD Crossfire mode through Radeon Settings.
A small subset of AMD Radeon R9 380 users may be experiencing slower than expected fan speeds. A work around is to raise your fan speeds through AMD Overdrive in Radeon Settings manually to a desired amount.
HDMI Scaling options may not be available in Radeon Settings on some system configurations.
Package Contents
The AMD Radeon Software Crimson Edition 16.4.1 Driver contains the following:
AMD Radeon Software Crimson Edition 16.4.1 Driver Version 16.15.2211.1001.
อยากลองQuantum break
...เพิ่งรู้เดี๋ยวนี้ Driver Amd อัฟเดทแบบออโต้ได้เหมือน Nvidia แล้วเพิ่งลองเมื่อกี๊ยังไม่มีปัณหาอะไร...อิอิอิ
