AMD Radeon Software Crimson 16.3.1 DirectX 12
  • AMD Radeon Software Crimson 16.3.1 DirectX 12
    Radeon Software Crimson Edition 16.3.1 Highlights
    Updated Crossfire Profiles available for:
    Hitman
    Support for:
    Need for Speed
    Resolved Issues
    Installed or played games sometimes do not show up in the Radeon? Settings "Gaming" tab.
    Installing via command line may not work for some users. As a workaround please use the default GUI installer.
    Intermittent hang sometimes experienced on UE4 applications.
    Black screen or possible hang after launching Oculus Video Application.
    DirectX 12 application frame rates are no longer locked to the refresh rate of the display panel.
    Known Issues
    A few game titles may fail to launch or crash if the AMD Gaming Evolved overlay is enabled. A temporary workaround is to disable the AMD Gaming Evolved "In Game Overlay"
    FFXIV can experience black screen or application hang
    The Division may experience flickering in AMD Crossfire mode.
    League of Legends may experience some graphical corruption on characters death animation in AMD Crossfire mode.
    Rift may experience a hang when playing with FRTC and V-Sync enabled. As a work around users are suggested to disable V-Sync.
    Plants vs Zombies: Garden Warfare 2 may experience some flickering in AMD Crossfire? mode.
    Power efficiency toggle in Radeon Settings is showing up for some unsupported products.
    Hitman may experience poor AMD Crossfire scaling when "Super Sampling" is set to 1.5x.
    Need for Speed may experience poor scaling or flickering in AMD Crossfire? mode.
    You can now download the new AMD Radeon Software Crimson Edition drivers release 16.3.1 driver Version March 18 2016. This driver is compatible with Windows 7, 8.1 and 10 DriverVer= 03/14/2016, 16.1...
    ...ออกใหม่อีกแหละ เพิ่งลง16.3ไปไม่ถึงสัปดาห์เลย 555
      เดี๋ยวนี้อัพไวมาก AMD
      สู้ๆ
        หนังตัวอย่าง crossfire knock SLI หลับกลางอากาศ
          กำลังรออยู่เลย 16.3.1 กดค้นหามา 4 วันแล้ว อิอิ
            พึ่งอัพ 16.3 ไปเมื่อวาน เหอๆ จะอัพเลยก็ขี้เกียจจัดไอคอนหน้าจอใหม่อีก
              มันจะมี 16.3.2 อีกไหมนิ
                ออกตามเกม ที่เกมเปิด ^^
                  และแล้วการ์ดแดงรุ่นเก่า ก็โดนลอยแพต่อไป
                    ถ้าไม่ช่วยอะไรในเกมเก่าๆ ก็ม่ายอัพ
                    ว่าแล้วกลับไป witcher ต่อ
                      ทำไมลงแล้ว Core/Mem ลดลงเหลือครึ่งเดียวหว่า ใครเป็นมั่งป่ะ
                        ใช้ ddu ลบไดวเวอร์
                        ใช้ ccleaner ล้าง รีจีสขยะวินโดว์
                        ลงไดวเวอร์ใหม่
                        ตามนี้ครับ
                        ถ้าไม่หาย ก็กลับไปใช้ตัวเก่าโลด
                        ผมยังไม่ได้ลง รออัฟเดทวินโดว์10 ตัวแพทใหม่ล่าสุดก่อน เดี่ยวลงบ้าง
                          Originally posted by THEFOOL View Post
                          ใช้ ddu ลบไดวเวอร์
                          ลงไดวเวอร์ใหม่
                          ตามนี้ครับ
                          รู้ปัญหาละ ไดเวอร์อะไรสักอย่างมันอาจไป ตีกับ Msi afterburner พอดี
                          Set การตั้งค่าพัดลมไว้ พอ Reset ตอนนี้ ปกติละ
                            เป็นเหมือนกันกัน..ลง msiafterburner แล้วเล่นๆสักพักค้าง..ต้องลบออกถึงจะไม่ค้างครับ...(เป็ฯตั้งแต่เวอร์ชั่น 16.3 ละ)
                              กำลังจะว่า ให้ลบ Msi afterburner ออกเหมือนกัน
