หลุดสเปค GP104 และ GP100
  • หลุดสเปค GP104 และ GP100
    It has been a very quiet season for NVIDIA. Unlike AMD, NVIDIA is very careful releasing any information about its future architecture called Pascal.
    Luckily, the so called leakers just can?t live without speculating and creating their own charts, because I suppose that?s exactly what we are seeing on this graph.
    GeForce X
    I?ve decided to post this chart only for two reasons. First I think the idea of GeForce X is quite interesting (but not necessarily true). The idea of GeForce X makes a lot of sense, but the problem starts when you start thinking about the next series (aka GeForce 1100).
    Presumably the GeForce X family would include such graphics cards:
    It looks familiar with GeForce GTX series, we are basically using shorter names, but it?s hard to see what would happen to GT, GTS and non-GT series. Also, do we really want to get rid of GTX branding?
    The move to 16nm FinFET is without a doubt a good reason to start with new naming schema. NVIDIA skipped desktop 800 series for a reason ? to deliver something fresh with FinFET chips.
    NVIDIA has a choice of succeeding GeForce GTX 980 series with GeForce GTX 1800 (judging from with Quadro line), or start something complete new, like GeForce X.
    As far as I?m skeptical about this ?leak?, it would actually explain what could happen to TITAN series. Rather than dropping the idea altogether, shorter naming could still ?accommodate? TITAN branding, avoiding the problem of card model sounding weird.
    GeForce X80
    Now let?s look at the chart. According to the data GeForce X80 would be the first GP104 based graphics cards. Presumably the GPU would have 4096 CUDA cores which is actually not that far from our predictions.
    The person who posted this chart has without a doubt did some homework. It is assumed that full GP104 would feature twice as many CUDA cores as GM204, but it is immediately suggested that full GP100 has 6144 CUDA cores. Does this sound familiar to you? That?s exactly what happened with GM204 and GM200, since Big Maxwell had 1.5x of GM204 cores.
    To my surprise leaker suggest that Pascal GP100 would support both GDDR5 and HBM2. Would NVIDIA design one chip with two different memory controllers on the same die? Also the leaker suggest HBM2 would have memory bus 4096-bit, but it should be 8192-bit.
    Another thing to consider is memory bus on GDDR5 parts. Would NVIDIA try to compensate the availability of HBM2 and GDDR5X chips by increasing clock speed and making memory bus wider? The 512-bit bus and 8 GHz clock already give us Fury X bandwidth, but NVIDIA has not used 512-bit in a long time, so is it really necessary?
    The 8000 MHz clock
    It gets more interesting when you notice memory clock of 8000 MHz. And that?s the second reason why I?m posting this chart. I?ve actually found some benchmarks of GPUs running at 2000 MHz (8000 MHz effective) and these were definitely not performed by the overclocker Kingpin..
    It never ring a bell to me that these could be new Pascal boards. The scores are not impressive (graphics scores), and GPU clock speeds are actually quite very low, so these could be a mobile engineering samples (usually tested on desktops). คะแนน 3DMark ข้างล่างน่าจะเป็นแค่ตัว Mobile Engineering Sample ไม่น่าจะใช่ Pascal Desktop ตัวจริง
    Unfortunately this post does not deliver super exclusive leak to you today, but it should start a discussion of what is the future of GeForce series, especially how is NVIDIA going to call them?
    We expect to see more such rumors before GPUTech conference in April, where Jen-Hsun has his ?opening keynote?, and hopefully has something to say about Pascal.
      เอ่อ... ชื่อมัน แบบว่า...
      จะใช้ x series จริงๆหรอ
      evga geforce x80ti kingpin แบบนี้หรอ อืม...
      เธอทำให้ฉันรู้สึกเหมือนตอน 14 ??
      ตอนที่ฉันมี geforce 2mx ตัวแรก
      ปล. เอาจริงดิ่ x80ti ยังใช้ ddr5 และมีแต่ titan ได้ใช้ hbm2
      ปล.2 อย่างน้อย x80ti ต้อง hbm จะไม่ดีกว่าหรอ อจ ประมาณ
        ตอนแรกผมก็คิดว่า GP100 จะได้ใช้ HBM2 ทุกรุ่น แต่ตอนนี้ดูเหมือนจะมีแต่ Titan ที่ได้ใช้ครับ
          เดวผมน้อยใจ หนีไปซบอกเหี่ยวๆเจ๊ลิซ่าซะเลย
            GDDR5X Bus 2000MHz คือลาก Mem มา ชิมิ
              พอเห็นแดงบอกจะยังไม่ใช้ HBM ในรุ่นใหม่นิกั๊กเลยนะเขียว ถ้าแดงออกมาแรงกว่าแล้วราคาเป็นมิตร จะย้ายไปซบแดงละ หมั่นไส้เขียว
                ถ้าขนาด น้ำดื่มตัว top ยังใช้แค่ hbm
                และ titan เป็นตัวแรกที่ใช้ hbm2
                ไม่อยากคิดว่าราคาจะเท่าไหร่ดี all new titan x series
                สงสัยจะ 50k+
                  ถ้าเดิมๆ 2000 ผมว่าอาจลากไป 2200-2300 ได้สบาย
                    คุณพระ TMUs / ROPs สูงมากๆ
                    นึกว่าจะมาช่วง volta ซะอีก 320+ / 160+ 4K 60Hz
                    เจ้า X80 นี่ น้องๆ 980 ref. Sli เลย
                      980Ti ก็ลากได้เกือบ 2100 อยู่เเล้ว ไม่อเมซิ่งเบย
                      แต่ Titan cuda โหดขิงๆ
                        ดูจากสเปคแลเว ความแรงระหว่าง 80ti กับ Titan เริ่มจะ***งชั้นขึ้นนะเนี้ย
                          All new X series ชื่อเข้าท่าดีนะ ฮาฮาฮา
                            ถ้าดูจากจำนวน Cuda Cores และหากไม่มีการเปลี่ยนแปลงของความแรงต่อคอร์
                            X80 คงแรงประมาณ 980 SLI
                            X80 Ti ประมาณ 970 3 Ways SLI
                            X80 Titan ประมาณ Titan X SLI
                              Titan ตัวนี้ผมเดาๆ ว่าอาจมีถึง 1200 เหรียญ
