น่าจะมาพร้อมกันกับคู่แข่งนะ
Pascal ของ N จะมาเมื่อไหร่ครับ
ข้อมูลล่าสุดจาก Techpowerup http://www.techpowerup.com/217652/nv...gtc-japan.html
NVIDIA revealed more details of its upcoming "Pascal" GPU architecture at the Japanese edition of the Graphics Technology Conference. The architecture will be designed to nearly double performance/Watt over the current "Maxwell" architecture, by implementing the latest tech. This begins with stacked HBM2 (high-bandwidth memory 2). The top "Pascal" based product will feature four 4-gigabyte HBM2 stacks, totaling 16 GB of memory. The combined memory bandwidth for the chip will be 1 TB/s. Internally, bandwidths can touch as high as 2 TB/s. The chip itself will support up to 32 GB of memory, and so enterprise variants (Quadro, Tesla), could max out the capacity. The consumer GeForce variant is expected to serve up 16 GB.
It's also becoming clear that NVIDIA will build its "Pascal" chips on the 16 nanometer FinFET process (AMD will build its next-gen chips on more advanced 14 nm process). NVIDIA is innovating a new interconnect called NVLink, which will change the way the company has been building dual-GPU graphics cards. Currently, dual-GPU cards are essentially two graphics cards on a common PCB, with PCIe bandwidth from the slot shared by a bridge-chip, and an internal SLI bridge connecting the two GPUs. With NVLink, the two GPUs will be interconnected with an 80 GB/s bi-directional data path, letting each GPU directly address memory controlled by the other. This should greatly improve memory management in games that take advantage of newer APIs such as DirectX 12 and Vulkan; and prime the graphics card for higher display resolutions. NVIDIA is expected to launch its first "Pascal" based products in the first half of 2016.
สรุป
- Pascal ตัวแรก (ในข่าวไม่ได้บอกว่าชิปไหน GP107 106 104 หรือ 100) จะมาช่วงครึ่งแรกของปีหน้า
- พวก Quadro Tesla จะใส่ HBM2 มาสูงสุด 32GB
- ขณะที่ Geforce จะใส่ HBM2 มาสูงสุด 16GB (คงเป็น Titan ตามเคย ส่วน 1080 Ti คงเหลือ 8GB)
- Bandwidth สูงสุด 1TB/S หรืออาจขึ้นไปสูงสุด 2TB/S
- จะมาพร้อม Nvlink ที่จะมาแทน SLI (คล้ายๆ XDMA ของ AMD)
- ทำบน 16nm Finfet process (AMD 14nm)
- เพิ่มประสิทธิภาพต่อการกินไฟ2เท่าเมื่อเทียบกับ Maxwell ถ้าเทียบง่ายๆก็ประมาณการ์ดแรงเท่า 980 Ti แต่กินไฟแค่ 100W นิดๆ
