R9 370 ภาพหลุดจาก AMD
  • R9 370 ภาพหลุดจาก AMD
    ขายที่ 149$ (ราคานี้ปกติได้แค่ 750 1GB เองนะ)
    สรุปว่าข่าวลือที่ว่า 3XX จะแพงกว่า 2XX ก็ไม่น่าจะจริงแล้วครับ
    ข่าวลือบอก 179$ ขายจริง 149$
      R7 370 จะราคาเท่าของเดิมรึเปล่าน่า $149 =R7 265 Ref. แรงกว่า 750Ti
        เป็น R9 270 ลด clock ลดราคามาทับ 265 ครับ
          AMD Radeon R7 370 Graphics Card Pictured ? 2 GB Memory and Compact PCB Design
          The Radeon R7 370 is based on the Pitcairn core architecture which was renamed to Curacao during the launch of Radeon 200 series. It can be expected that AMD won?t rename the chip again but the card is using the same nomenclature as its predecessor, the Radeon R9 270 series. The only thing that has changed is that AMD has decided to place it in the Radeon R7 series instead of the Radeon R9 series due to the large performance gap and the sub-$149 US pricing this card will feature. Everything above this card will be included in the Radeon R9 series that include the R9 380 series (Tonga) and R9 390 series (Hawaii).
          So why do we believe that AMD is using Pitcairn core inside the hood of this card? It?s simple, there?s a single Crossfire connector on the board instead of the recent XDMA technology which eliminates the need of gold fingers and channels data from cards through the PCI-Express bus. All of GCN 1.0 family use a CrossFire port while the Bonaire core is the only one to use such connector but it?s hard to see a Bonaire chip in such a high branding as the 370 when it was previously using the 260 series naming scheme. Since AMD hasn?t designed any new GCN 1.0 or 1.1 chip since Hawaii, it can be concluded that this is actually the Pitcairn based rebrand.
          Advertisements
          From the looks of the card, it can be seen that it uses a single Crossfire connector which allows 2-Way Multi-GPU functionality, a 6-Pin connector which leads to 150W typical board power (75W 6-Pin and 75W PCI-E). The rest of the PCB is quite compact and the display outputs include Dual-DVI, HDMI and a single display port. The card features a similar design scheme as the high-end Fiji parts and the same shroud surface texture can be seen on the card as well. The two Radeon logos can also be spotted however it is not known whether they too lit up in red when the card is operational. There?s a single blower type fan which sucks air inside the card and pushes hot air out of the exhaust vent at the back of R7 370 card.
          AMD Radeon R7 370 Performance
          The 6-Pin connector reveals that this card might be based on the Pitcairn XT revision featured on the R9 270 or the Pitcairn Pro revision featured on the R7 265 since the R7 270X demands two 6-Pin connectors and AMD just couldn?t magically cut down power consumption on the full core other than toning down the clock speeds as they did with the R9 270. The specifications may include 1280 stream processors, 80 TMUs, 32 ROPs which is the same as the Pitcairn XT but clock speeds could be toned down around 975 MHz range (Base/Boost). The 2 GB GDDR5 memory will operate along a 256-bit memory bus at 5.6 GHz clock speed, pumping out 179 GB/s bandwidth. It is highly likely that the Pitcairn XT will launch as the Radeon R7 370X graphics card later. In terms of performance, the card is aimed at the GeForce GTX 750 Ti (GM107 Maxwell) so it will be priced in the budget range and deliver 20% better performance as AMD?s own slide claims. There?s more to be revealed over the next couple of days so stay tuned.
          Read more: http://wccftech.com/amd-radeon-r7-37...#ixzz3cSxOPc8b
            R9 390x ตอนแรกก็เห็นราคา $499 ข่าวล่าสุดเหมือนจะเป็นราคา $449 อีก 6-7วันก็รู้ราคาจริง ตอนนี้รอราคาเปิด Fury อย่างเดียวแพงกว่า GTX 980ti นี่จบเลยยกเว้นรุ่น Top ตามข่าวที่ว่าจะซอยเป็น 3 รุ่น
              ตามข่าวรุ่นที่เหลือจะถูกกว่ามากๆครับ ตัวแพงเพราะบล็อคน้ำ
              เขียวเปิดราคามา 649$ แล้วก็มีแนวโน้มว่ารุ่น pro อาจอยู่แถวๆ 5XX แพงกว่า 980 หน่อยนึง
              เพราะตอน 290 มาพี่แกก็ชอบมาแนวนี้แหละให้เขียววางราคาก่อนแล้วลดราคาลงมา
              ถ้า 390X ราคา 399$ จริงๆนี่พอทนนะแต่ตอนนี้ R9 290X 8GB นี่มันราคา $359 เองนะครับพอๆกับ 970
              คิดว่า 390X ก็น่าจะราคานี้นี่แหละ
                390x = 12200 - 13600 บาท ไอ้หย่ะ อิ อิ
                  ดำดุดัน
                    เกม โลโก้ แดง กินเรียบ
                    R7 370 = R9 270 @ $149 vs 750Ti 5000+-
                    R7 370X = R9 270X @ $ 179 vs 760 6000+-
                    R9 380 = R9 285 @ $199 vs 960 6500+-
                    256bit vs 128bit
                    2GB ทั้งหมด
                      ราคา ถูกมาก ซัมเมอร์ sale เลย
                        Originally posted by aosbee View Post
                        ราคา เหมือนขายทิ้งเลย
                        ราคานี้จริงรับรองไม่มีคนด่า AMD จะมีแต่คนแซะ อย่าง R9 390x นี่ถึงไม่ชนะ GTX 980 แต่ก็แพ้ไม่ขาดเหมือนในกราฟ
                        อย่าง R9 370 มันก็ควรขายราคานี้อย่างน้อยก็แรงกว่า GTX 750Ti ถึงย้อมแมวก็น่าสนถ้าราคา 4000 บาทต้นๆ
                          ถ้าจะสู้ผมว่าAMDมาถูกทางแล้วครัช รอเลยครับโพ้ม
                            ถ้าราคานี่จริงๆ ร้องเจี๊ยกเลย
                            AMD ทำขายไม่ทันชัวร์ ใบกำกับภาษีถมหัวตายพอดีขายดีเกิน
                              ถ้ามีรุ่นที่แพงกว่าแต่แรงกว่า ซัก 10-15%
                              ผมว่าโอเคอยู่นะ
