r9 390x ยังไงกันแน่ครับนิ
  • r9 390x ยังไงกันแน่ครับนิ
    AMD Radeon R9 390, R9 380, R9 370 and R9 360 Series Rebrands Spotted
    Since a couple days, several speculations have popped up after the OEM series were declared as rebrands officially be AMD on their site. Most users assumed that the rebrands in the Radeon R300 OEM lineup will suggest that the actual lineup will also be based on rebrands using older cores such as Hawaii, Tonga and Bonaire. The only card which is new in sight is AMD?s Fiji graphics card which is based on a 28nm process. Previous rumors suggest that this chip will feature a 300W TDP and a 2.5D interposer with 4 GB HBM video memory dedicated on chip. On AMD?s Financial Analyst Day, we broke out the news and revealed the first renders of the Fiji based flagship graphics card which is meant to use a water cooled design and a quite cool form factor which kind of looks cool when it comes to flagship offerings. The render has since been confirmed when Johan Andersson of DICE revealed the card which he has received by AMD from testing.
    It is becoming more and more common that these high-end flagship cards get extra treatment from chip makers since they are the pride of the company. We can see similar stuff with NVIDIA who gave extra some extra treatment to the GeForce GTX Titan X with a black cooler design while the upcoming GeForce GTX 980 Ti will make use of the regular silver colored cooler. This reflects the enthusiast branding of products like the GM200 based Titan X and Fiji based AMD?s flagship card.
    Advertisements
    So how do we know the AMD based cards are rebrands? Speculation and listings on various databases does confirm that the majority (if not all) of cards from AMD will be rebrands based on some renowned cores such as Hawaii, Tonga, Pitcairn and Bonaire. Videocardz did reveal the same scenario a few weeks ago in their round up of the entire 300 series cards. The listings we found through ASUS?s forums reveals a few interesting cards which does confirm Videocardz findings and we will explain these in a moment. The cards revealed on ASUS forums include:
    ASUS R9390X-DC2-8GD5
    ASUS STRIX-R9380-OC-2GD5
    ASUS STRIX-R9370-OC-4GD5
    ASUS STRIX-R7360X-DC2OC2-2GD5
    ASUS R7360-2GD5
    The first thing we get by looking at the top-end card of this listing reveals that it is Hawaii simply because Fiji can not feature 8 GB HBM memory. It is limited to just 4 GB on Gen1 implementation through single-link chip design. On the other hand, we know that Hawaii offered in the 300 series family will be a 8 GB card as it will be based on custom designs at launch. The second card which we believe is Tonga is also quite spot on with the leaks, we know that the Radeon R9 285 Tonga features just 2 GB VRAM across a 256-bit bus. It confirms why we see a sudden VRAM gap between the Radeon R9 370 which is the Pitcairn based card that does come in 4 GB VRAM models. There?s a possibility that AMD introduces the full Tonga XT chip with 2048 stream processors in the line with 4 GB VRAM as the Radeon R9 380X. Rest of the lineup includes the Bonaire XT and Bonaire Pro based Radeon R7 360X and Radeon R7 360 cards which feature just 2 GB GDDR5 VRAM.
    Aside from this, there have also been listings of Radeon R9 390, Radeon R9 380, Radeon R9 370 series cards on HIS?s official website which can be seen in the images below. The launch is indeed scheduled in a few weeks so we can expect the AMD flagship going against NVIDIA?s flagship GeForce GTX Titan X which gets revealed in a couple of weeks at Computex 2015.
    Read more: http://wccftech.com/amd-radeon-r9-39...#ixzz3bG9ZU1EM
    มันไม่จริงใช่มั้ยครับนิ
    ประมาณว่าชิปใหม่ Fiji ที่มาพร้อม 4GB HBM จะไม่ใช้ชื่อ R9-3XX แต่จะตั้งชื่อแยกแบบ Titan แทนครับ
    ส่วน Rx-300 series เป็น rebranded หมดครับ
      รอตัวเป็นๆ เลยครับ ตามข่าวช่วงนี้ปวดหัวเฉยๆ
        ข่าว เอเอ้มดี ช่วงนี้ปวดหัวดีมาก ฝั่งซีพียูก็ทีนึงละเรื่องซอคเก้ต
          ถึง Rebranded 290X ก็ยังอัดแรม DDR5 512bit ที่แรงขึ้นอีก 250*4Mhz (1000Mhz) ได้ 384GB - 6000Mhz/512Bit
          ในขณะที่ของเดิม 1250*4Mhz (5000Mhz) ได้ 320GB /512Bit แถมปรับ GPU Clock เพิ่มอีก 50Mhz
          ก็คาดว่าน่าจะแรงเกิน GTX980 ไปราวๆ 8% แบบไม่ต้องทำนายอะไร R9 290X เดิมๆ ก็เสมอ GTX970 แล้ว
          แต่เรื่องกินไฟนี่ยังเหมือนเดิมๆไหม ต้องรอดูอันนี้น่าจะกินแน่นอน
          มาดูว่าตัว GTX980Ti / TITAN X VS Fiji XT ดีกว่า น่าสนุกกว่าเยอะ
            AMD R12 DRAGON (BALL) Z -------------------------- Fiji XT
            AMD R12 DRAGON (BALL) GT -------------------------- Fiji Pro
            เผ่น.............
              ก็ดี แต่ให้รอนานไปหน่อยนะ .... รอจนเลิกรอหละ = ="
                จะยังไงก็เอาที่พี่เร (Radeon) สบายใจนะ แต่ขอให้ประทับใจละกัน
                  เผ่น.............
                  +10
                    ผมสงสัยมานานล่ะ ข่าวมั่วๆแบบนี้มันสนุกยังไงรึ ? - -
                    พอตัวจริงออกมาก็ไปอ่านรีวิวกันอยู่ดีง่ะ ถ้าเป็นต่างชาติก็พอเข้าใจจะใด้ไปกางเต๊นท์รอซื้อหน้าร้าน
                      สงสัย
                      PSU 1050Watt Gold
                      390X 8GB $549 CF เอาไปชน $999
                      390 8GB $329 CF เอาไปชน $699-$749
                      ปรับปรุงเรื่อง Frame time + Driver
                        AMD คงจะชูโรงเรื่องรองรับ DX12 สมบูรณ์แบบทุกตัว ตั้งแต่ตัวเล็กสุดยันตัวท๊อป ซื่งอีกค่ายรองรับแค่รุ่นเดียวมังคับ คนคงย้ายมาเล่นเยอะละทีนี้เพราะ DX12
                          ไททัน อาจจะเจอ AMD R9 แคโทส ก็ได้ สายโหด 55555+
                            555555ถ้าเป็นตามข่าวจริง ผมว่ามีโอกาสตามรอยnvidiaสูง ตั้งชื่อรุ่นพิเศษแล้วอัปราคา ถ้าราคาแรงผมที่เป็นคนใช้แดง ณ ตอนนี้คงต้องโบกมือลาไป980ti
                              รอ ออก เถอะครับ เบื่อข่าวamdแล้ว
