ขอคำแนะนำชาวสีเขียว
  • #46
    เห็นฝรั่งเค้าสรุปข้อดีข้อเสียมา ตรงไหมครับ
    ตอนแรกดู Asus อยู่ แต่เจอบอกว่า Least effective cooling solution of the three concerning core, memory, and vrm temperatures. ซะงั้น
    MSI GTX 970 Gaming
    - *High maximum rated power draw (for overclocking purposes)
    - Quiet air cooling solution
    - Smallest/thinnest card (of the three compared); better for small cases and will perform better in sli configurations temperature wise
    - Features a metal plate/heatsink covering the memory IC's and some circuitry on the front side of the PCB; more effective cooling in comparison to the STRIX card
    Cons:
    - No backplate
    - *4 memory IC's on the rear side of the PCB; could result in lower overclocks due to no airflow/heatsink contact, also loses potential for a full cover block to properly cool all the memory IC's
    - *Poor vrm cooling solution; small secondary heatsink that receives little airflow due to the placement of the 2 fan HSF design
    ASUS GTX 970 STRIX
    Pros:
    - Passive cooling during idle/non-3d load; offers quieter performance
    - Backplate
    - *All 8 memory IC's are located on the front side of the pcb; better airflow and cooling (although the stock heatsink does not make any contact with the IC's), best solution when considering water cooling for highest memory overclocks
    Cons:
    - *Lowest stock TDP/Power limit; only 1 x 8pin ATX power connection, note this is fine for general overclocking and stock use but do not expect possible benchmark record performance
    - Least effective cooling solution of the three concerning core, memory, and vrm temperatures.
    Gigabyte GTX 970 Gaming G1
    Pros:
    - Highest factory core clock/boost
    - High maximum rated power draw (for overclocking purposes)
    - Most effective cooling solution (especially when it comes to VRM section of the board)
    - Best air cooled solution
    - *Highest stock TDP/Power Limit (for overclocking purposes)
    - Backplate
    - Most display connectivity 3xDP 1xHDMI 2xDVI
    Cons:
    - Loudest cooling solution of the three cards
    - Largest and tallest card; not ideal for small cases or Sli conifgurations
    • #47
      ในที่สุดก็จัดมาจนได้ อิอิ ขอบคุณทุกท่านที่เข้ามาช่วยกันนะครับ
      ปล. ออ ขอถามต่ออีกนิดนะครับว่า ต้องอัพเดทไดร์เวอร์ถึงเวอร์ชั่นไหนหรอครับที่บอกว่าแก้ปัญหา VRAM แล้ว
      • #48
        อัพล่าสุดไปเลยครับ
        • #49
          ยินดีกับการ์ดใหม่ด้วยครับ
          • #50
            350.05 ( Hotfix )
            • #51
              อ่า ไม่ได้ใช้เขียวมานานมาก หาปุ่มอัพเดทไม่เจอ
              มันมี auto update หรือ check for update ไหมครับ หรือว่าต้องไปโหลด Manual Patch เอาเองครับ ?
              • #52
                โหลดไปลงได้เลยนะ
                http://www.guru3d.com/files-details/...-download.html
                • #53
                  ใน 980 ตัวไหนเย็นสุดครับ
                  และกินไฟน่้อยสุดด้วย
                  • #54
                    ไอเย็นเนี่ยคงพอๆกันหมดครับเลือกที่ชอบเลยส่วนเรื่องกินไฟ ก็ต่างกันไม่มากอีกนั่นแหละครับ ถ้าจะสูงหน่อยก็พวก hof แต่ก็แลกมาด้วยความแรงครับ
                    • #55
                      ขอบคุณครับ ... ไอ hotfix นี่คือต้องมีตัวหลักก่อนหรือเปล่าครับ หรืออัพได้เลย
                      พอดีไปเจอ check update ละ ไปหาใน Nvidia Control panel ตั๊งนาน สุดท้ายต้องเปิดใน Geforce Experience
                      แต่กดอัพเดทมันก็บอกของผมตัวล่าสุดแล้วอ่ะ 344.48 หรือว่าต้องตั๊งค่าอะไรก่อน = =
