GALAX LAUNCHES NEW HALL OF FAME EDITION GTX 900 SERIES CARDS
GALAX, a leading manufacturer and innovator of extreme performance gaming hardware, today announced the long awaited successors to the world renowned Hall of Fame lineage with the release of the GTX 980 HOF and GTX 970 HOF. Following in the HOF tradition, each card is factory tuned with the highest core clock in its class. The true dominance of the GALAX HOF Series cards, however, lay in their completely unbridled potential for overclocking.
Only the best of the best GeForce GPUs make the cut for HOF edition products, and GALAX has taken every possible step with their in-house designed white PCB, ultra-premium components and an incredible 7 heat-pipe triple fan cooler to ensure that overclockers? skill and determination is the only thing standing between them and a new world record. GALAX exclusive Hyper Boost technology acts like a hardware turbocharger, increasing the maximum power delivered to the GPU with the push of a button. Dual BIOS further simplifies the tweaking process by enabling risk-free firmware updates and customization.
GTX 980 HOF: GTX 970 HOF:
CUDA Cores 2048 1664
Base Clock (MHz) 1304 1216
Boost Clock (MHz) 1418 1380
Key Features
Completely redesigned PCB layout from the ground up, optimised for GM204
10 layer manufacturing process in HOF signature pure white colour
Extended PCB width for optimised layout and cleaner signal
New completely redesigned ?Triple Force? cooler
2x 80mm fan + 1x 90mm fan
4x 8mm heat pipes + 3x 6mm heat pipes (total 7 nickel-plated heat pipes)
Copper base
Integrated MOSFET heatsink
Customisable top HOF LED (control blanking frequency, brightness with GFE)
Plastic cover with premium die-cast aluminum accents
Anodised Aluminum Backplate protects components and reinforces PCB
Next generation IR3595 Digital PWM controller provides 2X switching frequency vs. previous generation
8 phase GPU + 2 phase memory power
IR3555 with next gen DrMOS and 60A output
Aerospace-grade "GALAX Extreme Power Inductors" provide Ultra Long Life, Long Endurance and Low Noise versus normal power inductors
Hyper Boost technology acts like a hardware turbocharger, increasing fan speed and maximum power delivered to the GPU with the push of a button, Voltage tool (developed by enthusiasts) allows voltage beyond stock limits
Hardware dual BIOS simplifies the tweaking process by enabling risk-free firmware updates and customisation
Prelim internal overclocking results: >1.5GHz on air, >2.1GHz on LN2
หน้ากล่อง คล้ายๆ
ใครพอทราบกำหนดการนำเข้ามาขายในไทย กับราคามั้งครับ
ภาพจาก ตปท .
อยากได้ข้อมูลเพื่อ เก็บงบ ดูเวลา พึ่งปล่อยgigaไปเพื่อ สิ่งที่ชอบขาวๆกำลังจิมา ชอบมาตั้งแต่สมัยชี่รี่ 700
