Radeon R9 290X ระบบระบายความร้อนลักษณะเดียวกับ r9 295x2
-clocked to a nice 1100 MHz
-120mm radiator
-under 80 Degrees C at full load
-HIS applied two 8-pin PCIe power connectors to the PCB
-Under SKU code H290XQH4GD the product will be released with 4 GB of graphics memory. The memory is running default at 6 Gbps. The card comes with DVI, DP and HDMi connectors and will be available starting next week. As you can see from our photo's, the cooler is based on the Arctic Cooling Accelero Hybrid VGA cooler.
