How to convert DVD to M4V for iPhone?
  • How to convert DVD to M4V for iPhone?
    I?m pursuing a program which can help me convert DVD movies to M4V, so that, I can freely enjoy them on my iPhone.
    What's M4V?
    M4V is a file container format used by Apple's iTunes application. It is a video format developed by Apple and is very similar to MP4 format. Apple uses M4V files to encode TV episodes, movies, and music videos in the iTunes Store. M4V can also be used as an online video format.
    Step 1: Downloadand install DVD to iPhone Converter for Mac
    Step 2: And then, click ?Load Disc? button to Load DVD Disc. With this DVD to iPhone Converter for Mac, you can convert the DVD Disc and DVD Folder to MP4, MOV and M4V formats videos for iPhone.
    Step 3: Then you should select your output M4V format from the "Profile" drop-down list, which contains all the supported output formats. You can also input it in the text area to order the software to find it for you.
    Step 4: It provides users with a collection of video editing tools to help customize video effect. These tools can help you trim video for your needed length, crop video frame to get rid of unwanted black edges, join multiple video clips into a single file, add text/image watermark to personalize the video, and adjust Video Contrast, Saturation, Brightness, Hue and Volume according to your needs.
    Step 5: Click the "Convert" button to start converting your DVD disc to iPhone compatible M4V format.
