http://support.amd.com/en-us/kb-arti...dows-beta.aspx
The AMD Catalyst 14.6 Beta driver is notable release for us for a couple reasons:
Mantle is now enabled for notebooks based on AMD Enduro technology
Mixed-resolution AMD Eyefinity configurations are now supported for SLS
Performance improvements for Watch Dogs
Performance improvements for Murdered: Soul Suspect
Watch Dogs:
AMD Radeon R9 290X - 1920x1080 4xMSAA ? improves up to 25%
AMD Radeon R9 290X - 2560x1600 4xMSAA ? improves up to 28%
AMD Radeon R9 290X CrossFire configuration (3840x2160 Ultra settings, MSAA = 4X) - 92% scaling
Murdered: Soul Suspect:
AMD Radeon R9 290X ? 2560x1600 4xMSAA ? improves up to 16%
AMD Radeon R9 290X CrossFire configuration (3840x2160 Ultra settings, MSAA = 4X) - 93% scaling
AMD Eyefinity Verbesserungen:
Mixed Resolution Support
A new architecture providing brand new capabilities
Display groups can be created with monitors of different resolution (including difference sizes and shapes)
Users have a choice of how surface is created over the display group
Fill ? legacy mode, best for identical monitors
Fit ? create the Eyefinity surface using best available rectangular area with attached displays.
Expand ? create a virtual Eyefinity surface using desktops as viewports onto the surface.
Eyefinity Display Alignment
Enables control over alignment between adjacent monitors
One-Click Setup
Driver detects layout of extended desktops
Can create Eyefinity display group using this layout in one click!
New user controls for video color and display settings
Greater control over Video Color Management:
Controls have been expanded from a single slider for controlling Boost and Hue to per color axis
Color depth control for Digital Flat Panels (available on supported HDMI and DP displays)
Allows users to select different color depths per resolution and display
AMD Mantle enhancements
Mantle now supports AMD Mobile products with Enduro technologyEnables support for Multi-GPU configurations with Thief (requires the latest Thief update).
Battlefield 4: AMD Radeon HD 8970M (1366x768; high settings) ? 21% gain
Thief: AMD Radeon HD 8970M (1920x1080; high settings) ? 14% gain
Star Swarm: AMD Radeon HD 8970M (1920x1080; medium settings) ? 274% gain
AMD AM1 JPEG decoding acceleration
JPEG decoding acceleration was first enabled on the A10 APU Series in AMD Catalyst 14.1 beta, and has now been extended to the AMD AM1 Platform
Provides fast JPEG decompression
Provides Power Efficiency for JPEG decompression
Sapphire 7770 OC EDITION ลงแล้วปกติสุขดี เจอปัญหาเดียวจะมารายงาน
Watch Dogs:
One-Click Setup
