AMD Catalyst 14.1 Beta มาแล้ว
  • AMD Catalyst 14.1 Beta มาแล้ว
    คลิก --> โหลด
    Feature Highlights of The AMD Catalyst? 14.1 Beta Driver for Windows
    Support for the following new AMD Desktop APU (Accelerated Processors) products:
    AMD A10-7850K
    AMD A10-7700K
    Mantle Beta driver
    AMD's Mantle is a groundbreaking graphics API that promises to transform the world of game development to help bring better, faster games to the PC
    Performance gain of up to 45%(versus the DirectX version) for Battlefield 4 on the R9 290 Series
    Performance gain of up to 200% (versus the DirectX version) for Star Swarm on the R9 290 Series
    AMD Catalyst 14.1 Beta must be used in conjunction with versions of these applications that support Mantle
    It is expected that these applications will have future updates to support additional AMD Mantle features
    AMD Mantle Beta driver is currently supported on:
    AMD Radeon? R9 Series GPUs
    AMD Radeon? R7 Series GPUs
    AMD Radeon? HD 7000 Series GPUs
    AMD Radeon? HD 8000 Series GPUs
    AMD A10-7000 Series and AMD A8-7000 Series APUs
    ?????For additional details please see the AMD Mantle Technology FAQ on amd.com?
    Enhanced AMD CrossFire frame pacing ? Support for 4K panel and Eyefinity non-XDMA CrossFire solutions (including the AMD Radeon R9 280, 270 Series, 7900 Series, 7800 Series) and Dual Graphics configurations?
    ???Frame pacing ensures that frames rendered across multiple GPUs in an AMD CrossFire configuration will be displayed at an even and regular pace
    Supported on 4K panels and Eyefinity configurations
    Supported on AMD Dual Graphics configurations
    Supported on DirectX? 10 and DirectX 11 applications???
    Resolved issue highlights of AMD Catalyst 14.1 Beta??
    Resolves ground texture flickering seen in Total War: Rome 2 with high settings (and below) set in game
    Resolves flickering texture corruption when playing Call of Duty: Ghosts (multi-player) in the space station level
    ที่มา : http://support.amd.com/en-us/kb-arti...dows-beta.aspx
    และขอบคุณคุณ IInJIIsJ จากห้อง BF4 ที่เอาข่าวมาบอกนะครับ
    จัดไป ขอลอง starswarm ก่อนเลย ฟิ้วววววววววววว
      รอตัวเต็มดีกว่า ...
        เงิบ dx error ,จอขาว
          จัด Star Swarm Stress ไปก่อนสดๆ 1 เทส 7970@280X แรงเกินเท่าตัว
            ขอ Mirror หน่อยงับ โหลดเว็บ AMD ไม่ได้
              จัดมาแล้ว BF4 ค้าง กระตุก ห่วยกาก R290 ไอสาด ปรับโหมดแล้ว กระตุกทั้ง Mantle DX11 ปวดหัวเลยสาด
                  download in progress คิๆ
                      มันก็เว็บ AMD ไม่ใช่เหรอเฮีย =_=
                        ก็โหลดจากเวปamdแหละครับ ผมก็กำลังดาวโหลดอยุ่เนี้ย
                          รู้สึก bf 4 จะมีปัญหานะครับ งานเร่งก็แบบนี้ละครับ
                            กำ ขอโทษด้วยครับ ลืมเช็ค
                              BF4 เท่าที่ผมลองจะมีปัญหาเฟรมล่วงเป็นบางช่วงนะครับ
