CoD: Ghosts ลูกพี่เขียว
  • CoD: Ghosts ลูกพี่เขียว
    Nvidia released some info about some of the PC-specific features that Nvidia owners will be able to use in CoD: Ghosts. On the PC, Call of Duty: Ghosts players receive the definitive experience, with assets, display resolutions, and textures that best the 720p and 1080p experiences offered by the ?next-gen? Xbox One and PlayStation 4. With a NVIDIA GeForce GTX graphics card, PC players benefit massively from high-quality, high-precision NVIDIA HBAO+ Ambient Occlusion, NVIDIA TXAA temporal anti-aliasing, and in a forthcoming game update, NVIDIA GPU-accelerated animal fur, and NVIDIA GPU-accelerated PhysX effects.
    If you're unfamiliar with these PC-exclusive features, here's a quick rundown:
    *NVIDIA HBAO+ adds realistic Ambient Occlusion shadowing and shading around objects and surfaces that occlude light, with a considerably-higher degree of precision than previous AO techniques.
    *NVIDIA TXAA temporal anti-aliasing eliminates the distracting movement of anti-aliased lines and edges, and also eliminates other artifacts associated with anti-aliasing. Edge anti-aliasing is comparable with 8xMSAA, but at the performance cost of 4xMSAA.
    *NVIDIA GPU-accelerated animal fur will add high-quality, realistic, dynamically-reacting fur to Riley, NPC wolves, and multiplayer attack dogs.
    *NVIDIA GPU-accelerated PhysX will add realistic, dynamically-reacting particle effects throughout the game, dramatically enhancing their appearance.
    *Higher-resolution textures, effects and assets make full use of the available VRAM and system RAM of PCs, adding extra detail even at 3840x2160, the next-generation 4K Gaming resolution.
    In the not too distant future we'll have a complete GeForce.com Call of Duty: Ghosts Graphics and Performance guide for those seeking further detail, but in the meantime we present below the first Call of Duty: Ghosts, max-setting PC screenshots, showing you how the blockbuster title shines on next-gen ?4K Gaming? PCs, and how it app ears at the most popular PC gaming screen resolution, 1920x1080
    จัดหนัก ยัดทุกเทคโนโลยีที่ตัวเองมี
      เกม 3% ในท้องตลาดสินะ ที่ใช้ PhysX มองข้ามๆไปเหอะ ซื้อการ์ดเขียวไม่คุ้ม เกมใหม่ๆมีแค่แบทแมนกับCODโกสเองที่ใช้
      ปล.เพิ่งถอย 670 มา ในขณะที่ทุกสายตากำลังจับจ้องการ์ดซีรีย์ R9
        Activision เป็นบริษัทเกมที่ใหญ่ติด top 3 โลก ใหญ่กว่าบริษัทการ์ดเกมทุกบริษัทในโลกรวมกัน
        CoD เป็นซีรีส์ที่ทำเงินให้ค่ายชนิดที่ว่า การ์ดเกมรุ่นไหนก็เทียบไม่ได้แม้ซักขี้เล็บ
        เพราะฉะนั้น เขาไม่มีทาง "ทุบหม้อข้าว" ตัวเอง ทำตัวทำเงินทำทองของค่ายให้ทุกคนเล่นไม่ได้หรอกครับ เพราะถ้าทำแบบนั้นแล้วเสียตลาดไป มันเสียมูลค่าไปมหาศาลเลย ( อย่าฝันว่า พี่เขียว จะยัดตังค์ให้ Activision ได้ เพราะยัดจนบริษัทล้มละลาย ก็ไม่รู้ว่าจะได้เท่าที่ Activision ทำเงินจากซีรีส์นี้ได้หรือเปล่า )
        ตรรกะเดียวกันนี้ สามารถนำไปใช้กับเกมอย่าง BF4 กับค่ายแดงได้ด้วย...
          ก็เกมโปรโมตค่ายเขียว หัวกระทู้ก็เขียว ก็เลยอวยปนแซวนิดหน่อยเอง อย่าซีเรียส พอดีว่าผมก็เพิ่งตัดสินใจซื้อการ์ดจออยู่เหมือนกัน แล้วก็มักเจอ 3% จากแฟนๆการ์ดแดงอยู่เรื่อย *0*
          สุดท้ายซื้อการ์ดเขียวมา มันก็เล่น bf4 ได้ลื่นหัวแตกอยู่ดี ทำนองเดียวกันใครใช้การ์ดแดงอยู่เขาก็เล่นแบทแมนได้อีกเช่นกัน เรื่องแบบนี้มันก็รู้ๆกันอยู่อ่ะครับ เลยไม่ชอบการบลัพแบบดิสเครดิตประมาณว่า PhysX มีก็เหมือนไม่มีเพราะเกมในท้องตลาดที่ใช้มีไม่ถึง 3% อะไรทำนองนี้ อยากเชียร์อยากอวยอะไรก็บอกข้อดีของฝั่งที่เชียร์ ไม่ใช่มาดิสเครดิตอีกฝั่ง
            เห็นด้วยกับท่าน KarooKKooK ครับ ^ ^
            บริษัทเกมส์เขาต้องการยอดขายมากที่สุด ซึ่งก็เป็นเรื่องปกติของการทำธุรกิจ
            ก็เหมือนที่ท่านบอกอ่ะครับ ตั้งแต่เกมส์ BF4 แล้วหล่ะ ที่หลายคนวิจารณ์เรื่องค่ายการ์ดจอ
            COD Ghost ก็เหมือนกันแหละ เขาไม่มาเกี่ยงหรอกครับว่าต้องใช้การ์ดจอค่ายไหนถึงจะเล่นได้
                  แต่ถ้าให้พูด ผมก็ประหลาดใจเหมือนกันนะ...
                  เพราะ physX มันเป็นอะไรที่เอาไปใช้เลยไม่ได้ ผู้พัฒนาต้องยอมให้วิศวกรของ nVidia เข้าไปดูแลในขั้นตอนพัฒนาด้วย ( ไม่เหมือนกับพวก Unreal Engine อะไร ที่คุณซื้อปุ๊บ คุณจะเอาไปปู้ยี่ปู้ยำยังไงก็เรื่องของคุณ )
                  แล้วกับซีรีส์เกม fps ออนไลน์อันดับ 1 ของโลก ซึ่งมูลค่าตลาดเกินกว่ายอดขายของบริษัทอุปกรณ์คอมขายกันทั้งปีอีกมั้ง ทุกอย่างต้องปิดเป็นความลับ แน่นหนาสุดๆ พลาดไม่ได้แม้แต่นิดเดียว
                  ผมว่าในสายตาผู้พัฒนา เขาคงไม่อยากให้ใครก็ไม่รู้มายุ่งกับโปรเจ็คของเขานะ ยิ่งเป็นโปรเจ็คหมื่นล้านแบบนี้...
                  แล้วไฉนเลย nVidia ไปเจรจายังไง Activision ถึงยอมได้ ต้องเป็นมือเจรจาขั้นเมพจริงๆ ( เพราะเงินไม่มีผล เนื่องจาก nVidia เล็กกว่า Activision เยอะมากๆ )
                  อาจต่างกับ BF4 ตรงที่ว่า Mantle มันเป็นมาตรฐานเปิด ใครอยากเอาไปใช้ก็เอาไป ไม่เข้าใจก็โทรมาหา AMD พอ ( อันนี้พูดเล่น ) พวกนี้มันจะ friendly กับผู้พัฒนามากกว่า...
                    ถ้าเกม ทีออกมามันบอกไม่ว่า BF4, Crysis3, CodGhost ห้ามใช้การ์ด เขียวเล่น ห้ามใช้การ์แดงเล่น แล้วมันจะ มีการ์ดจอ ATI Nvdia ไว้ทำไมหว่า ในเมื่อผลิตออกมา เล่นเกมไม่ได้
                      ต่อไปการ์ดจะแบ่งโซน ครับ โซนเล่นเล่นเกมส์แดง โซนเขียวเล่นโซนเขียว ฮาๆ
                      ส่วนผม นั่งเล่นเฟสบุ๊คสบายใจ
                        ถ้าแบ่งจริงนะ คนคงหนีไป Console หมดแหงครับ(ผมก็คนนึงแหละ) 555
                          phys x เหมือนกับว่าเคยอ่านผ่านๆตา ไม่แน่ใจนะครับ ว่าnvidia ไม่ได้คิดเงินเลยครับ แต่ต้องแบ่งส่วนกำไรของเกมมาให้ตน นี่เป็นอีกเหตุผลหนึ่งครับที่ไม่ค่อยมีเกมที่สนับสนุนphys x แล้วส่วนการสนับสนุนเงินที่ amd ให้กับ bf4 เพื่อที่จะให้ตัวเองมี gamer evoตอนเข้าเกมส์นั้นสูงถึง 8 ล้านเหรียญ
                            มันคงไม่แย่ขนาดนั้นหรอก ต้องมาแบ่งเกมส์แบ่งสี ขนาดแบทแมนตอนแรกผมใช้13.9เปิด aa8x เฟรมไม่เกิน40 แต่พอเจอ13.11เบต้า6 เฟรมทะลุ80เลย 7950@1ghz
                              ตลาดพีซีก็เล้กอยู่แล้ว ยังจะแบ่งอีกเรอครับ ผมว่าผู้ผลิตไม่คิดฆ่าตัวตายแบบนั้นแน่ๆ
                              ...ระบบPhysX Fur ใช้ในpatch หน้าครับ เพื่อการสวิงขนน้องหมาเราครับ...ปล...ดูท่าจะแปลกๆฮ่ะ เข้าสมรภูมิรบ ใครมันจะไปดูขนน้องหมาเราปลิ้วไปปลิ้วมาละครับ เปลื่องเครื่องสุดๆๆ
