มาแล้วสเปคเกมดูหมา
  • มาแล้วสเปคเกมดูหมา
    Ubisoft has released a new set of minimum requirements for the PC version of Watch Dogs, but has revised its ambitions …
    If Watch Dogs is to be believed, you can hack almost any electronic device in a city using nothing but a smart phone. First, though, you'll need to run Watch Dogs, which is going to require something with significantly more power inside of it. Ubisoft have updated their digital store with the open world hacking game's system requirements, and there are some surprises to be found in its
    ขั้นต่ำ Quad Cores , 6GB , Windows Vista 64bit แต่ดูเหมือนจะไม่ค่อยเน้นการ์ดจอเท่าไร Recommend เอาแค่ 460/5850
    Minimum requirements:
    Supported OS: Windows Vista SP2 64bit, Windows 7 SP1 64bit, Windows 8 64bit
    Processor: Intel Core 2 Quad Q8400 @ 2.66Ghz or AMD Phenom II X4 940 @ 3.0Ghz
    RAM: 6 GB
    Video Card: 1024 VRAM DirectX 11 with Shader Model 5.0
    Sound Card: DirectX 9 compatible Sound Card
    This product supports 64-bit operating systems ONLY.
    Recommended requirements:
    Processor: Core i7 3770 @ 3.5Ghz or AMD FX-8350 @ 4.0Ghz
    RAM: 8 GB
    Video Card: 2048 VRAM DirectX 11 with Shader Model 5.0 or higher
    Sound Card: Surround Sound 5.1 capable sound card
    Supported video cards at time of release:
    nVidia GeForce GTX460 or better, GT500, GT600, GT700 series
    AMD Radeon HD5850 or better, HD6000, HD7000, R7 and R9 series
    Intel Iris Pro HD 5200.
    Whats changed between the last requirements and the current requirements?
    The minimum Watch Dogs System Requirements has jumped up from 4GB RAM to needing 6GB of RAM minimum for Watch Dogs.
    The minimum Watch Dog processor requirement has jumped from an Intel Q6600 and AMD Phenom X4 9750 up to Intel Q8400 and AMD Phenom II X4 940.
    So in short the requirements we posted up last week seem pretty accurate apart from you actually need a little bit more powerful computer to run Watch Dogs.
    หนุกป่ะครับ ไม่เคยเล่น ^ ^
      เกมยังไม่ออกเลยท่าน naizz ใจเย็นๆ
        Next Gen กำลังมาเรื่อยๆ BF4 , Watch Dogs , GTA V
        เหมือนปีนี้จะมีการเปลี่ยนแปลงสเปคเกมครั้งใหญ่ เกมเริ่มรองรับ64บิทกันมากขึ้น กิน CPU หลายหัวมากขึ้น แรม8GBเริ่มจะไม่พอ
          Game Debate อีกแล้ว รู้ ๆ กันอยู่ว่าเวปนี้มันมั่วแต่ก็ชอบเอามาส่องดูให้จิตตกเล่นกัน
                โอ้โห มันเล่นขอ i7 กับ Fx8350 บ้าไปแล้ว จะเอาหัวไปทำไรขนาดนั้น 55+
                    อันนี้แก้จาก 3930K แล้วนะครับ แล้วที่มามีหลายเวปด้วย
                      3930k! แม้เจ้าเกมบ้าอะไรวะเนี่ย 5555
                        Minimum requirements ระบุซีพียู Quad Core
                          ผมงงกับชื่อ เกมอะครับ หมาหลับ บ้าง ดูหมา บ้าง ฮ่าๆ
                            หมาหลับน้ั้น sleeping dog ครับ ไอตี๊ซ่า ป่วนเมือง อันนี้ watch dog ดูหมา
                              จริงๆแล้ว watch dog แปลว่า สื่อมวลชน ประมาณนี้อะครับ
                              เปรียบเทียบประมาณว่าคอยจับดูสิ่งต่างๆอะไรแบบนี้อะครับ
