AMD Catalyst 13.9 WHQL display driver for Windows 8.1/Windows 8/Windows 7 - this is the first AMD Catalyst driver certified for Windows 8.1.
FEATURE HIGHLIGHTS OF AMD CATALYST? 13.9
The AMD Catalyst 13.9 WHQL is AMD?s first logo certified driver for Windows 8.1. It does not include support for Frame Pacing or the very latest AMD CrossFire? optimizations. AMD Catalyst 13.10 Beta includes additional performance improvements and fixes not found in AMD Catalyst 13.9 WHQL.
Includes WDDM 1.3 support for:
AMD Accelerated Processors (?Kabini? & ?Temash?) for Desktop, Notebook or Tablet PCs, including: A4-1200, A4-1250, A4-5000, A4-5100, A4-5150, A6-1450, A6-5200, A6-5250, A6-5350, E1-2100, E1-2200. E1-2500, E1-2600, E1-2650, E2-3000, E2-3100
AMD Accelerated Processors (?Richland?) for Desktop or Notebook PCs, including: A10-5700, A10-5745M, A10-5750M, A10-5757M, A10-5800B, A10-5800K, A8-5500, A8-5500B, A8-5545M, A8-5550M, A8-5557M, A8-5600K, A6-5345M, A6-5350M, A6-5357M, A6-5400B, A6-5400K, A4-5145M, A4-5150, A4-5300, A4-5300B
AMD Accelerated Processors (?Trinity?) for Desktop or Notebook PCs, including: A10-4600M, A10-4655M, A10-4677M, A10-5700, A10-5800B, A10-5800K, A8-4500M, A8-4555M, A8-4557M, A6-4400M, A6-4455M, A6-5400B, A6-5400K, A4-4300M, A4-4355M, A4-5300, A4-5300B
AMD Radeon HD 8000 Series
AMD Radeon HD 7000 Series
AMD Radeon HD 6000 Series
AMD Radeon HD 5000 Series
Support for AMD Features:
AMD Eyefinity
OpenCL?
OpenGL
UVD
AMD Dual Graphics/AMD CrossFire Technology
AMD Overdrive?
AMD Catalyst Control Center/Vision Engine Control Center
OpenGL support for User Profiles and Catalyst Application Profiles
Users can now create, per application, 3D setting profiles for OpenGL applications.
OpenGL applications are now supported through Catalyst Application Profile updates (for single GPU and AMD CrossFire configurations).
The AMD Catalyst Control Center now shows which applications are active on the Performance GPU and the Power saving GPU.
AMD Enduro? Technology enhancements:
RESOLVED ISSUES
Severe flicker in Far Cry? 3 game cinematic that may continue into gameplay.
BSOD crash when enabling CrossFire in the AMD Catalyst Control Center after installing a third AMD Radeon HD7790 graphics card.
BSOD crash in Windows 8 when display turns off (idle/sleep mode).
AMD Catalyst Control Center crash after creating an Eyefinity Group.
Disappearing mouse cursor in Windows 8 after completing the AMD Catalyst Driver installation and rebooting the system.
Cyberlink PowerDVD stop working with a pop-up error message during playback of a Blu-Ray movie under Power Saving mode.
When Dual Graphics is disabled within AMD Catalyst Control Center, the secondary display connected may not enable.
Frame drops experienced during playback of interlaced Blu-Ray content when all visual quality settings are enabled in AMD Catalyst Control Center.
Significant game performance slowdowns when moving the mouse cursor in World of Warcraft using DirectX 9 rendering mode.
Anti-aliasing and anisotropic filtering settings saved within created AMD Catalyst Control Center application profiles do not apply correctly.
Windows 8 Metro applications experience very low FPS when Dual Graphics is enabled in the AMD Catalyst Control Center.
AMD Eyefinity
OpenCL?
OpenGL
UVD
AMD Overdrive?
RESOLVED ISSUES
