Following up on launches of its GTX 780 HOF and GTX 770 HOF high-end graphics cards,
Galaxy is giving final touches to its next addition to the HOF (hall of fame) series, this one based on the performance-segment GeForce GTX 760 GPU. Pictured below, the GTX 760 HOF is, for all intents and purposes, GTX 770 HOF with a different GPU and memory chips, the pin-compatible GTX 760, and slightly slower 6 GT/s rated memory chips.
The GTX 760 HOF features the same milky, almost edible-looking white PCB characteristic of HOF series, which draws power from a pair of 8-pin PCIe power connectors, and conditions it using an 8-phase VRM, which uses CPL-made chokes, and IR DirectFETs. An NEC-Tokin Proadlizer (multi-phase capacitor) keeps power delivery to the GPU clean.
The card ships with factory overclocked speeds of 1111 MHz core, 1176 MHz GPU Boost, and 6.00 GHz memory. It features 2 GB of GDDR5 memory across a 256-bit wide memory interface. Galaxy didn't reveal launch details. Find more pictures at the source.
ที่มา - http://www.techpowerup.com/188617/ga...-pictured.html
