GeForce GTX 660 - On your average system the card requires you to have a 450~500 Watt power supply unit.
GeForce GTX 660 SLI - On your average system the cards require you to have a 700 Watt power supply unit as minimum.
If you are going to overclock GPU or processor, then we do recommend you purchase something with some more stamina.
