AMD Catalyst? 13.3 Beta3 มาจากเวป AMD โดยตรง
  • AMD Catalyst? 13.3 Beta3 มาจากเวป AMD โดยตรง
    AMD Catalyst? 13.3 Windows? Beta Driver
    Back
    Last Updated
    3/19/2013
    Article Number
    RN-WIN-B13.3
    Get help with AMD products. Download drivers, find documentation, explore developer tools, and access support for graphics, processors & more.
    NOTE! AMD Catalyst? 13.3 Beta3 includes all of the fixes found in previous versions of AMD Catalyst 13.3 Beta.
    Feature Highlights of the AMD Catalyst? 13.3 Beta3 Driver for Windows?
    ?Resolves OpenGL application issues seen with the AMD Catalyst 13.3 Beta2 driver
    The AMD Catalyst? 13.3 Beta3 Driver can be downloaded from the following link:
    ?AMD Catalyst 13.3 Beta3 for Windows
    NOTE! This Driver is provided ?AS IS? and under the terms and conditions of the End User License Agreement provided therewith.
    Feature Highlights of the AMD Catalyst? 13.3 Beta2 Driver for Windows?
    ?Improve performance in Sim City 5 up to 16 percent
    ?Improves performance in Far Cry 3 up to 5 percent
    ?Improves latency performance issues seen in Tomb Raider and Hitman Absolution
    ?Resolves slight corruption seen in Tomb Raider with TressFX enabled for CrossFire and single GPU configurations
    System Requirements:
    ?Windows 8 (32 & 64-bit versions)
    ?Windows 7 (32 & 64-bit versions with SP1 or higher)
    ?Windows Vista (32 & 64-bit versions with SP2 or higher)
    AMD Product Compatibility:
    ?AMD Radeon? HD 7900 Series
    ?AMD Radeon HD 7800 Series
    ?AMD Radeon HD 7700 Series
    ?AMD Radeon HD 6000 Series
    ?AMD Radeon HD 5000 Series
    ?AMD Mobility Radeon HD 7000M Series
    ?AMD Mobility Radeon HD 6000M Series
    ?AMD Mobility Radeon HD 5000 Series
    AMD ISSUE REPORTING FORM:
    This driver release incorporates suggestions received through the AMD Issue Reporting Form. To provide us with your feedback, visit the appropriate form:
    ...13.3เบต้า2 เพิ่งโหลดมา2-3วันยังไม่ได้ลงเลย......
      เพลียจริง ๆ = ='
      พึ่งลง beta2 ไป 3 วันแล้ว มาอีกแล้ว
      #Resolves OpenGL application issues seen with the AMD Catalyst 13.3 Beta2 driver
      แก้ไขเรื่อง OpenGL สิ่น้ะ
        แก้บัคเรื่อง เกมที่ใช้ OpenGL เล่นไม่ได้
        แล้วพวก โปรแกรมต่างๆ ที่ใช้ OpenGL ใช้งานไม่ได้
          มาเเว้วๆ
            ของเก่ายังไม่ได้ลองเลย
              น่าลองมากเลยท่าน
              ทำไงถึงจะได้ลอง
                ผมเพิ่งจะลง 13.3 b2 ไปเมื่อคืนนี้เอง ขยันอัพจริงไรจริง
                  ไดร์เวอร์ จะเปลี่ยนทุกสิ่ง (:
                    เพิ่งลงไป 3 วันก่อน เอง กำๆๆ
                      อัพบ่อยๆ คลายเหงา ตัวจริงไม่ออกซักที
