มาแล้วครับไดร์เวอร์ตัวใหม่ล่าสุดสำหรับผู้ใช้การ์ดจอของทางค่าย NVIDIA ^ ^
NVIDIA GeForce 314.21 BETA Driver
รายละเอียดก็ตามนี้ครับ (ที่มา Guru3D.COM)
http://www.guru3d.com/files_details/geforce_314_21_beta_driver_download.html
GeForce 314.21 BETA Driver as released by NVIDIA mostly to help out with performance and stability improvements in Tomb Raider.
It also adds new SLI and 3D Vision profiles.
Release Summary
Improves performance and stability in Tomb Raider
Adds new SLI and 3D Vision profiles.
Additional Details
Installs PhysX System Software 9.12.1031.
Installs HD Audio v1.3.23.1
Includes support for applications built using CUDA 5 or earlier version of the CUDA Toolkit.
Supports OpenGL 4.3 for GeForce 400-series and later GPUs.
Supports DisplayPort 1.2 for GeForce GTX 600 series GPUs.
Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
Supported Products
ION (Desktops)
ION
ION LE (Desktops)
ION LE
GeForce 600 Series
GeForce GTX 690, GeForce GTX 680, GeForce GTX 670, GeForce GTX 660 Ti, GeForce GTX 660, GeForce GTX 650 Ti, GeForce GTX 650, GeForce GT 645, GeForce GT 640, GeForce GT 630, GeForce GT 620, GeForce GT 610, GeForce 605
GeForce 500 Series
GeForce GTX 590, GeForce GTX 580, GeForce GTX 570, GeForce GTX 560 Ti, GeForce GTX 560 SE, GeForce GTX 560, GeForce GTX 555, GeForce GTX 550 Ti, GeForce GT 545, GeForce GT 530, GeForce GT 520, GeForce 510
GeForce 400 Series
GeForce GTX 480, GeForce GTX 470, GeForce GTX 465, GeForce GTX 460 SE v2, GeForce GTX 460 SE, GeForce GTX 460, GeForce GTS 450, GeForce GT 440, GeForce GT 430, GeForce GT 420, GeForce 405
GeForce 300 Series
GeForce GT 340, GeForce GT 330, GeForce GT 320, GeForce 315, GeForce 310
GeForce 200 Series
GeForce GTX 295, GeForce GTX 285, GeForce GTX 280, GeForce GTX 275, GeForce GTX 260, GeForce GTS 250, GeForce GTS 240, GeForce GT 230, GeForce GT 240, GeForce GT 220, GeForce G210, GeForce 210, GeForce 205
GeForce 100 Series
GeForce GT 140, GeForce GT 130, GeForce GT 120, GeForce G100
GeForce 9 Series
GeForce 9800 GX2, GeForce 9800 GTX/GTX+, GeForce 9800 GT, GeForce 9600 GT, GeForce 9600 GSO, GeForce 9600 GSO 512, GeForce 9600 GS, GeForce 9500 GT, GeForce 9500 GS, GeForce 9400 GT, GeForce 9400, GeForce 9300 GS, GeForce 9300 GE, GeForce 9300 SE, GeForce 9300, GeForce 9200, GeForce 9100
GeForce 8 Series
GeForce 8800 Ultra, GeForce 8800 GTX, GeForce 8800 GTS 512, GeForce 8800 GTS, GeForce 8800 GT, GeForce 8800 GS, GeForce 8600 GTS, GeForce 8600 GT, GeForce 8600 GS, GeForce 8500 GT, GeForce 8400 GS, GeForce 8400 SE, GeForce 8400, GeForce 8300 GS, GeForce 8300, GeForce 8200, GeForce 8200 /nForce 730a, GeForce 8100 /nForce 720a
เลือก Download ตาม Windows ที่ใช้นะครับ
Download Windows Vista - 7 - 8 (32-bit Driver)
Download Windows Vista - 7 - 8 (64-bit Driver)
Download Windows Vista - 7 - 8 32-bit Driver Notebook
Download Windows Vista - 7 - 8 64-bit Driver Notebook
Download Windows XP 32-bit Driver
Download Windows XP 64-bit Driver
Release Summary
Additional Details
Supported Products
ION (Desktops)
ION
ION LE (Desktops)
ION LE
GeForce 600 Series
GeForce 500 Series
GeForce 400 Series
GeForce 300 Series
GeForce 200 Series
GeForce 100 Series
GeForce 9 Series
GeForce 8 Series
