มาแล้วครับไดร์เวอร์ตัวใหม่ล่าสุดสำหรับผู้ใช้การ์ดจอของทางค่าย AMD ^ ^
AMD Catalyst 13.3 BETA 2 (12.100.17.0 March 14)
รายละเอียดก็ตามนี้ครับ (ที่มา Guru3D.COM)
http://www.guru3d.com/files_details/amd_catalyst_13_3_beta_2_download.html
This AMD Catalyst 13.3 driver is compatible with AMD Radeon HD 5000, HD 6000 and HD 7000 Series graphics cards. This display driver supports Windows Vista/Windows 7/Windows 8 both the 32 and 64-bit versions.
Feature Highlights of the AMD Catalyst 13.3 Beta Driver:
Improves performance in Far Cry 3 up to 5 percent
Improve performance in Sim City 5 up to 16 percent
Improves latency performance issues seen in Tomb Raider and Hitman Absolution
Resolves slight corruption seen in Tomb Raider with TressFX enabled for CrossFire and single GPU configurations
Build Info:
12.10.17-130314a-154593E-ATI
DriverVer=03/14/2013, 12.100.17.0000
Catalyst: 13.3
CCC: 2013.0314.1701.28699
D3D: 9.14.10.0968
OGL: 6.14.10.12172
OCL: 10.0.1124.2
AMD Product Compatibility:
AMD Radeon HD 7900 Series
AMD Radeon HD 7800 Series
AMD Radeon HD 7700 Series
AMD Radeon HD 6000 Series
AMD Radeon HD 5000 Series
AMD Mobility Radeon HD 7000M Series
AMD Mobility Radeon HD 6000M Series
AMD Mobility Radeon HD 5000 Series
System Requirements:
Windows 8 (32 & 64-bit versions)
Windows 7 (32 & 64-bit versions with SP1 or higher)
Windows Vista (32 & 64-bit versions with SP2 or higher)
'Download Click'
Build Info:
Catalyst: 13.3
D3D: 9.14.10.0968
OGL: 6.14.10.12172
OCL: 10.0.1124.2
'Download Click'
