MSI Afterburner 3.0.0 BETA 6 สดๆ
  • MSI Afterburner 3.0.0 BETA 6 สดๆ
    MSI Afterburner 3.0.0 Beta 6 Download - Guru3D and MSI have been working hard on AfterBurner, today we release an updated this Beta revision of Afterburner, this application successfully secured the leading position on graphics card utilities.
    Today we release an updated Beta revision of Afterburner, this application successfully secured the leading position on graphics card utilities. We're happy to see MSI Afterburner is leading the overclock applications. MSI Afterburner 3.0.0 Beta is ready, this version supports the control of NVIDIA GeForce GTX Titan, if you get the card, you may want to try it.
    This build contains the following fixes:
    ?Fixed abnormal RTSS.exe CPU usage
    ?Fixed bug in thermal formula interpretator on triple temperature monitoring capable graphics cards (e.g. MSI R7970 Lightning), which could prevent application from starting properly on such cards
    ?Reverted to 32-bit time_t usage to provide backward compatibility with third party applications (gadgets and so on)
    ?Updated localizations
