Gigabyte GTX670 4GB overheating
  • Gigabyte GTX670 4GB overheating
    System setup:
    Cosmos II case
    MB: Z9pe-d8 ws
    GPU: 3x GTX670 4GB
    Gpu temperature is around 95-100c on 100% load. (running iray)
    Is this normal?
    3Dsmax activeshade viewport also lags a lot when overheating.
    Any suggestions?
    Thanks
    check fan speed (RPM)
      I think claim for get new device.
        พัดลมเหมือนจะไม่หมุน
          I think your graphic fan card doesn't work, so maybe you need claim it.
            Just checked krub. Fan indeed isnt spinning This is my 3rd Gigabyte card...
            Many thanks krub
              Also, I can't wait for the warranty card so hoping to get a new card. Any recommendations?
              Galaxy 680 4gb
              Asus 670 4gb
              eVGA gtx680 4gb
              Which one should I go for? Thanks
                Asus = easy claim, good quality, quiet fan (Direct CU models)
                Galaxy = low price, decent quality, poor service/claim (from what I heard)
                evga = great quality, moderate fan noise, warranty can be tricky since there are very few local dealers in Thailand
                Why can't you type in Thai? Are you living in a foreign country?
                  I haven't got a thai keyboard krub (need to get one soon).
                  Basically, I have got a deadline this Friday and one of my GPU just died.
                  Hoping to get hold of 4x gtx680 (4GB) today. Any idea where to get hold of them? They have to be 2slots if I want to run 4, would only be able to run 3x if they are 3slots thick like my current gigabytes.
                  I really want to try the Asus out since noise level of the gigabyte is pretty unacceptable on 100% load.
                  Thanks.
                    Sorry for the answer in Thai word just only me. - -'
                      ผมไม่มี keyboard ไทยครับต้องทายเอา
                        ลองร้านนี้ http://www.busitek.com/page/pricelist.html#display
                        670 ที่กินเกิน 2 สล็อตคือ inno3d ichill กับ Palit Jetstream
                        680 ที่กินเกิน 2 สล็อตคือ Asus DC2 กับ inno3d ichill และ gigabyte ทั้งรุ่นสามพัดลมและ SOC ส่วน palit 680 ไม่แน่ใจเหมือนกัน
                          Seem's like only Gigabyte 680 is available in 4GB version (3 slots). Looks like I will have to stick with gigabyte
                          Thanks anyway.
