เห็นเมโมรี่ 4GB มันน่าลองมั้ยครับ แต่ดูราคาแค่ สองพันกว่าบาทเอง มันจะเหมาะกับงานแบบไหนครับ
http://www.inno3d.com/product/gt630_4gb_dual.html
Technical Specifications
Inno3D GeForce GT 630 4GB Dual Slot
Product Cataegory
Series Inno3D
Segment GT (Essential)
GPU Engine Specs:
CUDA Cores 96
Graphics Clock-Base Clock / Boost Clock (MHz) 810
Processor Clock (MHz) 1620
Texture Fill Rate (billion/sec) 13
Memory Specs:
Memory Clock (MHz) 1066
Standard Memory Config (MB) 4096
Memory Interface SDDR3
Memory Interface Width 128-bit
Memory Bandwidth (GB/sec) 17
Feature Support:
OpenGL 4.1
Bus Support PCI-E2.0 X16
Certified for Windows 7 Yes
Supported Technologies (3D Vision, 3D Vision Surround, CUDA, DirectX 11, PhysX, SLI) CUDA, DX11, PhysX
SLI Options Not Supported
Display Support:
Multi Monitor Yes
Maximum Digital Resolution (per output) 2560x1600
Maximum VGA Resolution (per output) 2048x1536
HDCP Yes
HDMI Yes
Standard Display Connectors HDMI, Dual Link DVI, VGA
InternalAudio Input for HDMI Internal
HDMI Version 1.4a
Standard Graphics Card Dimensions:
Length 160mm
Height 106mm
Width Dual slot
Thermal and Power Specs:
Maximum GPU Temperature (in C with ambient temperature 55c) 98 C
Maximum Graphics Card Power (W) 65W
Minimum System Power Requirement (W) 300W
Supplementary Power Connectors Not Applicable
Cooler:
Fan Type Axial
Number of Fan 1
Number of Heatpipe Not Acquired
Accessories:
Driver CD Kit 1
DVI Dongle 0
Mouse Pad 0
6-pin PCI-E Power Cable 0
Product Cataegory
Series Inno3D
GPU Engine Specs:
CUDA Cores 96
Memory Specs:
Feature Support:
OpenGL 4.1
Display Support:
Multi Monitor Yes
HDCP Yes
HDMI Yes
HDMI Version 1.4a
Length 160mm
Height 106mm
Width Dual slot
Cooler:
Fan Type Axial
Number of Fan 1
Accessories:
Driver CD Kit 1
DVI Dongle 0
Mouse Pad 0
