- _-* ตอนนี้ลองเล่น bf3 แล้วค้างเล่นไปประมาณ5-10 นาทีต้องกด ctrl+alt+del
จึงออกได้ ใครเป็นเหมือนเขาบ้าง มีวิธีแก้ไหมคับ
GPU overclock calculation was fixed for pre-Kepler NVIDIA GPUs. Crashes on systems with broken high-precision event timer implementation (HPET) were fixed, and so were several memory leaks.
The change-log for this version follows. Fixed GPU-Z window getting cut off on non-standard DPI settings Fixed overclock calculation error on NVIDIA non-Kepler GPUs Fixed GPU-Z not starting or crashing the machine on systems with broken HPET implementation Fixed SLI not getting detected under Windows XP Fixed garbled board name on some older Radeon cards Fixed several memory leaks L6788A voltage controller on HD 7750 and HD 7770 will now display correct default voltage Added support for NVIDIA Tesla M2070
