mediainfoครับ
General
Unique ID : 253133181168989331630500598401758869443 (0xBE6FAD6703DD20188756582D5DEF37C3)
Complete name : I:\K-ON! The Movie.mkv
Format : Matroska
Format version : Version 2
File size : 2.87 GiB
Duration : 1h 49mn
Overall bit rate : 3 745 Kbps
Movie name : [CoalGuys] K-ON! Movie
Encoded date : UTC 2012-07-25 20
00
Writing application : mkvmerge v4.0.0 ('The Stars were mine') built on Jun 5 2010 17
09
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High 10@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 49mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4
0
Bit depth : 10 bits
Scan type : Progressive
Writing library : x264 core 120 r2120 0c7dab9
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.06 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=1 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60
Default : Yes
Forced : No
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 1h 49mn
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Title : Audio
Language : Japanese
Default : No
Forced : No
ใช้การ์ดจอเรนเดอร์ขึ้นDXVAเป็นปกตินะครับ
เรื่องอื่นเปิดได้ไม่มีปัญหาเพิ่งมาเป็นไฟล์นี้ครับ
spec:
CPU: PHENOM II X6 1055T เดิม
Cooling:CoolerMaster 212 EVO
M/B: ASUS M5A88V-EVO
VGA:Gig GTS450
RAM: KINGSTON1333 DDR3 16GB(4*4GB)
Hdd: (WD Blue 500GB)*2<<Raid0+(WD Green 2TB) *1
Case: Thermatek V3 BE
PSU : Gouriki3-500a 500W 80+
General
Format : Matroska
Duration : 1h 49mn
00Writing application : mkvmerge v4.0.0 ('The Stars were mine') built on Jun 5 2010 17
09Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Duration : 1h 49mn
Color space : YUV
0Bit depth : 10 bits
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 49mn
Title : Audio
Language : Japanese
Default : No
Forced : No
spec:
VGA:Gig GTS450
