NVIDIA Inspector 1.9.6.6
ของเล่นใหม่ ของคน OC Nvidia ครับ
Version 1.9.6.6
clock domains reworked, fixed some 304.xx issues on kepler
switched shader to gpu clock for monitoring default selection
updated some setting constants for 302.xx drivers
Version 1.9.6.5
fixed wrong bandwidth calculation for GDDR3
added invalid bios detection
added some vendorids
finally fixed trilinear optimization setting 1 = off / 0 = on
changed prerenderlimit setting for 0 (is now app controlled since 300.xx)
minor changes in default value handling
updated some settings constants for 300.xx drivers
added CLI param "-restartDisplayDriver" (Vista/Win7 only)
Version 1.9.5.9: (Hotfix)
fixed function 'ChangeWindowMessageFilter' not available on XP
fixed frame rate limiter is already included since 280.26+ drivers
Version 1.9.5.8:
improved profile combo handling to fix searching while dropdown is open will not change selected profile
added image upload feature to driver profile settings toolbar
holding CTRL while launch Monitoring from mainapp will start Monitoring standalone
[you can close inspector in this case without closing monitoring but they wont share sensor readings anymore]
for profile settings you can drop a shortcut to the game EXE now and it will open the assigned profile
