ผลเทส GT640 มาละ
  • ผลเทส GT640 มาละ
    ห่วยกว่า GTS450
    Benchmark the model "GeForce GT 640" for the low end of the Kepler
    GV-N640OC-2GI
    On sale 10,980 yen: actual selling price
    GPU "GeForce GT 640" for low-end (640 or less) has been released from NVIDIA, which adopted the Kepler architecture. Now that you get the video card "GV-N640OC-2GI" made by GIGABYTE this time, with a 640 this, to convey a report that mixes a very simple benchmark. The purchase price was 10,980 yen.
    ? Kepler's first desktop-based low-end model
    NVIDIA GPU series for low-end, prior to the announcement of 640, began the transition to the 600 series with the introduction of 610/GT 620/GT 630 GeForce, 610/GT 620/GT 630 400 series and this is both renaming of the old product in the 500 series, the so-called Fermi architecture, was not a Kepler-based architecture of GeForce GTX 680 has been adopted by the upper.
    640 was released on June 4 is a product based on the Kepler architecture, but for desktop becomes first adopted. CUDA seems to be the number of core 384 has been based, this is equivalent to spec, such as the previously announced GeForce GT 650M for mobile, and was diverted to this core.
    Are core clock of reference is 797MHz, the memory is DDR3, bus width 128bit, memory clock and 1.782GHz. In addition, 640 products and equipped with GDDR5, has been equipped with Fermi core product lineup, at the time of June 4 in the market could not be confirmed either. Even among good company GV-N640OC-2GI was obtained this time, has become a model of Kepler-based core with DDR3.
    The following table summarizes the lineup of the series was 600 GeForce GT, 640 has become the top in the GT series can be seen from this table.
    GeForce GT 600 series comparison [Table 1]
    GT 610 GT 620 GT 630 GT 640
    Architecture Fermi Kepler
    Core clock 810MHz 700MHz 810MHz 720MHz 797MHz 950MHz
    The number of core CUDA 48 96 144 384
    CUDA core clock 1,620 MHz 1,400 MHz 1,620 MHz 1,440 MHz 797MHz 950MHz
    Memory type DDR3 GDDR5 DDR3 GDDR5
    Memory bus width. 64bit 128bit 192bit 128bit
    Memory speed 1,800 MHz 3,200 MHz 1,782 MHz 5GHz
    ? GV-N640OC-2GI
    Before moving on to the benchmark, I want to touch on GV-N640OC-2GI body first.
    Substrate length (not including bracket) First that comes in a very short and 144mm, this area, such as for low-end place indeed. GV-N640OC-2GI cover of the cooler has a protruding about 35mm from the board, has become a card length of around 180mm but as a result.
    Cooler but that, in type 2 slots occupied, but the heat sink as reference LGA1155 CPU cooler Intel, made of aluminum, fin is growing radially. In addition, fans have become a thing of the 9-bladed 95mm in diameter but thin. This area seems to be the result of an emphasis on low-end while cooling. Moreover, the bracket also arranged the exhaust port, that is doing the cooling air may be seen to.
    Not provided with the PCI Express auxiliary power connector on the card, which works only with power supply from PCI Express. Implementation and around the power supply has become so simple either. This area also has become such as to suggest that it has been designed for mobile from the beginning.
    Display interface DVI-D ? 2, includes mini D-Sub15 pin, the HDMI. Because a two-stage bracket, but was dressed a systematic increase output with it.
    Although not covered by warranty, apparently to remove the cooler, model number of GPU and memory could be confirmed. GPU is stamped "GK107-300-A2", certainly does not seem in the GK107 core of Kepler. The size of the chip is 11 ? 11mm in (width ? depth), die size and I can guess around 120 mm square by actual measurement. Memory is "K4W2G1646C-HC11" of Samsung, DDR3 is for graphics, has become a product spec sheet 1.8Gbps According to the data of the other hand.
    Package of accessories, such as GV-N640OC-2GI GV-N640OC-2GI body Output interface
    A large cooler with a fan Cooler occupies two slots I removed the GPU cooler
    Mark of the GK107-300-A2 K4W2G1646C-HC11 memory of Samsung Simple power supply unit
    Result of the GPU-Z
    In addition, the core clock of this product is 1,050 MHz, memory and overclocking has been driving 1.8GHz. But memory is a memory OC to the standards as adopted, the core clock is 32% higher than calculated reference setting. However, the 640 was released at the same time it was in spite of all companies DDR3 model, the model is nil, all have become more than 900MHz core clock as reference. This time in the clock continue to benchmark this remains so.
    ? benchmark environment
    The benchmark environment as shown in the table below. You determine CPU but rather underpowered Pentium G630T, to become a stumbling block in consideration of the balance of the entire system, to test for low-end GPU would not first.
    Test environment [Table 2]
    CPU Pentium G630T (2.3GHz)
    Memory Kingmax KHX1600C8D3K2/4GX (2GB ? 2, DDR3-1600)
    Motherboard P8Z77-I Deluxe
    SSD Kingmax SNV125-S2/30GB
    OS Windows 7 Ultimate (64bit)
    Power Abee ZUMAX ZU425
    Driver version NVIDIA GeForce R300 Driver Ver.301.42
    "GF PGTS450SuperOC/1GD5 FUJIN 2.1" of the Galaxy
    Choice for comparison was the "GF PGTS450SuperOC/1GD5 FUJIN 2.1" of the Galaxy. The will should be compared with the "GeForce GT 440" In the model number, this is because it has been renamed to GeForce GT 630, was clearly subordinate position.
    On the other hand, was originally to be prepared or very close to the "GeForce GTX 550 Ti" and "GeForce GTX 560 SE" that price range, that could not be prepared in relation to the schedule. Therefore, it was equipped with a GeForce GTS 450 GF PGTS450SuperOC/1GD5 FUJIN 2.1 (below 450) you want to score published as a reference.
    In addition, overclocked to 4GHz is a model by a 888MHz / memory clock to core clock This product will also be predicted performance and do not receive a step after the 550 Ti. Same 128bit memory bus width is 640 and for the same, it may say 640 but a good rival.
    ? Mark the relatively good score in DirectX 11
    Performace preset of "3DMark 11" First there is a (graph 1), has come (-2.7%) as far as a step close to 450 in both the overall score, score graphics, it can be said with quite good results. Kepler?????????????????????????????????
    Graph [1] 3DMark 11
    Testing the DirectX 11 "Heaven Benchmark 3.0" of Unigine (graph 2,3), but at 1,366 ? 768 dot close to -3.8% to 450, with a resolution (WUXGA) is about -14.3% 1,920 ? 1,200 dot also were weaned.
    Graph [2] Heaven Benchmark 3.0 score
    [3] Heaven Benchmark 3.0 frame rate graph
    Memory bandwidth of the GV-N640OC-2GI is computationally 28.8GB/sec, less than half of 64GB/sec of GF PGTS450SuperOC/1GD5 FUJIN 2.1. This area has been pulling the foot of a high-resolution score. Can also be viewed as that can maintain the performance of over 80% of 450 in the half band width Conversely, in the Kepler architecture be seen also that the good use of memory bandwidth, however.
    Also the result of (graph 4) DirectX of "Lost Planet 2" of 11 DirectX 11 enabled games benchmark, to mark the performance of around about 90% compared with GF PGTS450SuperOC/1GD5 FUJIN 2.1, showed a good score. Although there are two generations ago, would say with the results so far can be close to the GTS of handling up a notch in that NVIDIA, the name of Kepler is not ashamed of highly efficient architecture.
    Graph [4] Lost Planet 2 (DX11) benchmark
    ? DirectX 10/9 is somewhat weak. Shackles or memory bandwidth
    Benchmark "3DMark Vantage" 10 DirectX DirectX 9 compatible benchmark but (Graph 8), here is the GF PGTS450SuperOC/1GD5 FUJIN 2.1 (graph 5,6), "3DMark06" (graph 7), "Lost Planet 2" followed by The result was a little place to go. Over 80%, and led to the result of 3DMark06 SM 3.0 of WUXGA particularly good performance is only about 70% did not.
    Of course, it's also optimized drivers seems to be in these benchmarks is light shader program itself, and has become a stumbling block rather large memory bandwidth. It has become particularly noticeable difference between the score of high-resolution, instead of GDDR5, the adoption of DDR3 memory will be missed.
    Graph [5] 3DMark Vantage
    Graph [6] 3DMark Vantage Feature Test
    Graph [7] 3DMark06
    Graph [8] Lost Planet 2 (DX9) Benchmarks
    ? GPU power consumption and temperature
    Finally, the power consumption during idle and run but 3.0 Heaven Benchmark (Graph 9), idle time has left a very excellent results with 81W 39W, even when the load in the entire system. Even considering that this is a version overclocked to both products, "(of course, but comparisons in Heaven Benchmark) Daseru beating by the power consumption of less than half the performance of approximately 90%" It that is the impact of hard.
    If this power, in 640 non-OC version, such as adopting a model with low TDP CPU also on the side of addition, if a little twist Korase, this will be able to drive in 1 AC Adapter 90W. Only that was also adopted for mobile truly is.
    ????9?????
    In addition, the GPU temperature, 37 ? at 26 ? idle in an environment of room temperature, was 44 ? (at run 3.0 Heaven Benchmark) at full load. It can not be compared side by side because of the different cooler, considering that 42 ? even when idle GF PGTS450SuperOC/1GD5 FUJIN 2.1 of cooling mechanism ambitious adopted two heat pipes, it was 69 ? when fully loaded, very good and the results would say.
    [10] GPU temperature graph
    About the static sound, but a subjective evaluation, the sound is almost no wind noise and axis both at the time / full load when idle, and the result was good. The only unfortunate but point the coil squeal a little when full load rather hear, this is also, there is a possibility of individual differences, the level will not be heard once housed in the case.
    ? Recommended for light use. DDR3 prices and neck is adopted
    The above is carried out a very simple benchmark, it is impressive that "the percentage of low heat generation high-performance, low power consumption" than anything else. If you are getting high efficiency only this would be done to smooth alternation of generations of low-end.
    Become a bottleneck of this product, and the lack of DDR3 memory bandwidth due to the adoption, the price of the product probably will. As is evident, with DDR3 memory bandwidth shortage has been pulling his feet from the bench results. Products with GDDR5 is regrettable in this issue is resolved, only to be expected better results than 450.
    Prices, but has been released from ? 8,000 units, many models are more than 10,000 yen, in this price range even comes into view as well as 560 SE GeForce GTX 550 Ti GeForce GTX. In addition, it is also crowded market Radeon HD 7750/7750 of a rival. 640 enters the choice is multiplied if the balance power and performance, when considered in cost performance, it is divided into other products. Offered at the price you have, you become able to obtain less than 7,000 yen, the low-end will be decisive.
    ? NVIDIA website
    http://www.nvidia.co.jp/
    ? Products
    http://www.nvidia.co.jp/object/geforce-gt-640-oem-jp.html
    ? GIGABYTE website
    http://www.gigabyte.jp/
    ? Product (sales CFD, Distributors)
    http://www.cfd.co.jp/gigabyte/vga/gv-n640oc-2gi.html
    ? Related Articles
    NVIDIA - June 4, 2012], "GeForce GT 640" of Kepler-based
    http://pc.watch.impress.co.jp/docs/news/20120604_537590.html
    (June 12, 2012)
    [Takashi Liu Reported by]
    ซะงั้น หน่ะ
        3,650บาท ส่ายหัวเลย ใครอยากประหยัดไฟเชิญตัวนี้เลย
          3,650 นี่ราคาไม่ไหวมั้ง
            เล็กไป
            รอดู GTX 660 / GTX 650
              ราคากับความแรงการ์ดไปด้วยกันไม่ได้
                ซะงั้น ไหนว่าแรงกว่า 450 อยู่ 25% ไง
                  ผมล่ะงงกับ Cuda 640 มัก ๆ ให้มา 384 cuda ? สงสัยที่เค้าว่า Cuda ใน Kepler ประสิทธิภาพมันน้อยกว่าใน Fermi เห็นจะจริง เพราะถ้า cuda 384 ใน Fermi นี่ก็คงแรงสูสี 560Ti แหง ๆ (แต่นี่สู้ 450 ยังไม่ได้เลย กำ) ความจริง 640 ถ้าแรงประมาณ 450-550 ในแบบไม่ต้องต่อไฟนี่จะดูคุ้มกว่านี้นะ
                  ปล.เขียวก็ยังคงสู้แดงในรุ่นรากหญ้าไม่ได้ซักที (ความแรงต่อราคาไม่โดนจริง ๆ)
                    แป๊ก
                      นี่ไม่น้อยนะ แรงเบียด 7750 แล้วนะนี้
                      edit: ไปดู 7750 ที่ techpowerup แล้ว ขอเปลี่ยนคำพูด
                        สรุปว่าดีกว่า 6670 ไช่ใหม ? น่าสนใจอยู่นะ
                        ไม่ไช่ไม่ชอบแดง แต่ 7750 รู้สึกไม่ชอบรหัสมันเลย ด้วนๆ ยังไงพิกล -*-
                          รอ 645
                            Originally posted by Phawatpong View Post
                            รอ 645
                            เหมือนรอ 685 หรือป่าวท่าน 5555+
                              ใช่ครับ
