AMD Radeon? HD 6450
AMD Radeon? HD 6450 GPU Feature Summary
625-750 MHz engine clock
512MB-1GB DDR3/GDDR5 memory
533-800 MHz DDR3 (1.066-1.6 Gbps) or 800-900 MHz GDDR5 (3.2-3.6 Gbps) memory clock
8.5-12.8 GB/s (DDR3) or 25.6-28.8 GB/s (GDDR5) memory bandwidth
200-240 GFLOPS Single Precision compute power
TeraScale 2 Unified Processing Architecture
160 Stream Processing Units
8 Texture Units
16 Z/Stencil ROP Units
4 Color ROP Units
GDDR5/DDR3 memory interface
PCI Express 2.1 x16 bus interface
DirectX? 11 support
Shader Model 5.0
DirectCompute 11
Programmable hardware tessellation unit
Accelerated multi-threading
HDR texture compression
Order-independent transparency
OpenGL 4.1 support
Image quality enhancement technology
Up to 12x multi-sample and super-sample anti-aliasing modes
Adaptive anti-aliasing
Morphological anti-aliasing (MLAA)
16x angle independent anisotropic texture filtering
128-bit floating point HDR rendering
AMD Eyefinity multi-display technology1
Native support for up to 3 simultaneous displays
Up to 4 displays supported with DisplayPort 1.2 Multi-Stream Transport
Independent resolutions, refresh rates, color controls, and video overlays
Display grouping
Combine multiple displays to behave like a single large display
AMD App Acceleration2
OpenCL 1.1
DirectCompute 11
Accelerated video encoding, transcoding, and upscaling2,5
UVD 3 dedicated video playback accelerator
MPEG-4 AVC/H.264
VC-1
MPEG-2 (SD & HD)
Multi-View Codec (MVC)
MPEG-4 part 2 (DivX, xVid)
Adobe Flash
Enhanced video quality features
Advanced post-processing and scaling
Dynamic contrast enhancement and color correction
Brighter whites processing (blue stretch)
Independent video gamma control
Dynamic video range control
Dual-stream 1080p playback support
DXVA 1.0 & 2.0 support
AMD HD3D technology4
Stereoscopic 3D display/glasses support
Blu-ray 3D support
Stereoscopic 3D gaming
3rd party Stereoscopic 3D middleware software support
Cutting-edge integrated display support
DisplayPort 1.2
Max resolution: 2560x1600 per display
21.6 Gbps bandwidth
High bit-rate audio
HDMI 1.4a with Stereoscopic 3D Frame Packing Format, Deep Color, xvYCC wide gamut support, and high bit-rate audio
Max resolution: 1920x1200
Dual-link DVI with HDCP
VGA
Max resolution: 2048x1536
Integrated HD audio controller
Output protected high bit rate 7.1 channel surround sound over HDMI or DisplayPort with no additional cables required
Supports AC-3, AAC, Dolby TrueHD and DTS Master Audio formats
AMD PowerPlay? power management technology3
Dynamic power management with low power idle state
AMD Catalyst? software and HD video configuration software
Unified graphics display drivers
Certified for Windows 7, Windows Vista, and Windows XP
AMD Catalyst? Control Center
Software application and user interface for setup, configuration, and accessing special features of AMD Radeon products
