It is no surprise that Nvidia is working on a dual-GPU graphics card that will feature two 28nm GK104 Kepler GPUs, but Expreview managed to dig out a couple of fresh tidbits about this card and now we are hearing that it is set for release in June.
According to a post over at Expreview, the new GTX 690 will draw power from two 8-pin PCI-Express power connectors and will feature PCI-Express 3.0-compliant bridge chip. The PSU requierement is set at 650W and the card will feature three DVI and one Displayport outputs. According to our info, precise specifications are still not finallized as Nvidia can use any of the recently rumoured versions of the GK104 chip.
Currently, our latest info puts the GTX 690 release at sometime in June but as always take such information with a grain of salt.
You can check out Expreview post here.
