Addendum:
- stock vGPU voltages for this card are 1.05v (2D idle) and 1.10v (3D load)
- stock vMEM voltage for Qimonda GDDR3 (HYB18H512321BF-10) is 1.80v ±5%
- 1kΩ (or higher) variable resistor can be used for the vGPU mod in order to maintain the minimum voltage close to stock. A 500Ω VR will force the vGPU slightly higher than stock vGPU even when the VR is tuned for the lowest vGPU = maximum resistance.
- vGPU pencil mod turned out to be virtually impossible
- usage of a multimeter is strongly recommended
- ENJOY!
สู้ๆนะครับ ผลเป็นไงก็เอามาโชว์กันมั่งนะ เอิ้กๆๆๆ
