AMD HD Radeon 7900 Series
  • AMD HD Radeon 7900 Series
    มันกำลังจะมา
      According to the information at hand, AMD wishes to end the 2011 year by winning the accolades for the best microprocessor and the best graphics processor in the world. In order to do that, the company brought forward the launch of Radeon HD 7970, which was revealed here. As you know, AMD's CEO Rory P. Read proudly announced that the company started to ship the 28nm GPUs for revenue, and there are numerous leaked pictures, pricing rumors and an alleged specifications slide leak.
      Now, it looks like the Radeon HD 7970 will launch on December 22, 2011, bringing a Christmas gift to all the current AMD users and those that want to become one. This will be a very limited launch, with the real availability only coming on January 9, 2012 - which should be the launch date for the Radeon HD 7950.
      The interesting bit about the Radeon HD 7950 is that the board is coming out as a custom part, and AMD gave freedom to partners to clock the part anyway they want, there is flexibility in terms of amount of memory, 3rd party cooling - just like GeForce GTX 560 launch, expect a lot of different parts coming from all the usual suspects.
      As far as HD 7950 availability is concerned, several sources in the know gave out conflicting information. One information floating around claims a limited launch on December 22 for HD7970 only, with widespread availability of HD7970 and HD7950 coming on January 9, 2012, and another rumor is that both HD7970 and 7950 are coming on December 22, 2011, albeit in very limited quantities. Again, both sides of the coin revolve around Dec 22nd and Jan 9th.
      The truth will be known on next Thursday, December 22nd.
      ที่มา http://gsngaming.com
        อ่านจากในเว็บเห็นเค้าบอกว่า Amd บอกราคา 7970 ราว ๆ 17,000 บาท จริงแท้ไม่รู้ ถึงจะแรงต่างกันมาก แต่ถ้าขายราคานี้ ผมเลือก 6970 แบบไม่ต้องคิดเยอะเลย ฮ่าๆ
          กำ ถ้า17000 จิง คิดหนักเลยนะครับ
            ห้ามเกิน 12,000 บาทนะ
              ราคา
              รุ่น 7950 12000 บ.
              7970 16000 บ.
              ปีก่อน ตัว top ไม่แพงเพราะ มันสู้ 580 ไม่ได้ ปีนี้ ชน 680 ได้แน่ ราคาไม่สบายกระเป๋า แล้วครับ
                รอดูต่อไป....
                  ตามนั้น.....
                    อยากดูตัวอืนมั้ง 7850 7870 อะไรยังงี้อ่า เมือไรจะมีข่าวมั้ง แรงแค่ไหนประหยัดไฟแค่ไหน
                      งวดนี้ขายแพงขึ้น สงสัยจะเอาเงินมาโปะฝั่งซีพียู
                        ราคานี้จริงผมไปซื่อ6990 เล่นแทน
                          ราคานี้ผมสอย GTX590 ในบอร์ดดีกว่า ราคาพอกัน
                            7970 3GB GDDR 384Bit ผิดที่คาดไว้ทั้งหมด ไหนล่ะที่ใช้ memory แบบใหม่มันยังเป็นGDDR5อยู่เลย
                              อาจจะไม่ได้คาดผิดหรอกครับ
                              แต่เป็นการกั๊กขั้นสุดท้ายไว้เจนหน้า
