AMD Cat 11.10 Preview 3
  • AMD Cat 11.10 Preview 3
    Download AMD Cat 11.10 Preview 3
    AMD Catalyst? 11.10 Version 3 Preview Driver Features:
    Reduces random crashing and stability encountered when playing Rage on Windows? 7 32-bit edition
    Reduces object / animation flickering and texture corruption encountered when playing Rage
    Reduces stuttering seen on Dual CPU and Tri CPU core systems
    Improves performance in Battlefield 3 Open Beta release for both non-Anti-Aliasing and application enabled Anti-Aliasing cases on single GPU configurations using the AMD Radeon? HD 6000 and AMD Radeon HD 5000 series of products.
    Improves performance in Battlefield 3 Open Beta release for both non-Anti-Aliasing and application enabled Anti-Aliasing cases on AMD CrossFire? configurations using the AMD Radeon HD 6000 and AMD Radeon HD 5000 series of products.
    Improves performance in Rage on single GPU configurations using the AMD Radeon HD 6000, AMD Radeon HD 5000 Series and AMD Radeon HD 4000 series of products.
    Reduces intermittent crashing seen loading levels in Rage
    Reduces flickering of NPCs in Rage
    Enables automatic Vsync for Rage
    Enables support for AMD Eyefinity 5x1 display (portrait and landscape) configurations using the AMD Radeon HD 6000 and AMD Radeon HD 5000 series of products.
    AMD Vision Engine Control Center: User Interface enhancements have been implemented for the AMD CrossfireX?, GPU AMD Overdrive? and Information Center pages.
    AMD Catalyst? 11.10 Preview 2 Driver Features:
    Improves performance in Battlefield 3 Open Beta release for both non-Anti-Aliasing and application enabled Anti-Aliasing cases on the AMD Radeon? HD 6000 and AMD Radeon HD 5000 series for single GPU configurations.
    Improves performance in Rage on single GPU and AMD CrossFire configurations using the AMD Radeon HD 6000, AMD Radeon HD 5000 Series and AMD Radeon HD 4000 series of products.
    Resolves intermittent crashing seen loading levels in Rage
    Resolves flickering of NPCs in Rage
    ออกทำม้ายยยยย BF3 beta มันปิดไปแล้วเนี่ย 555555+
      ตัวนี้ดีครับ เล่น RAGE ได้ดีขึ้นกว่า Preview2
        มีตัวใหม่มาแล้วนะท่านอยู่ในห้อง AMD แน่ะ
          +100,000,000 คะแนนเลยครับ
          เมื่อวานเอาไปลองเกม RAGE แล้ว ผลออกมาประทับใจมาก เห็นว่า Preview 3 ได้ปรับหลายอย่างให้รองรับอะไรต่างๆมากมาย
          อย่างเกมเก่าๆแบบ GTA4 ก็ลองแล้วครับไปเล่นอีกรอบ เฟรมสูงขึ้นอีกด้วย ไม่รู้คิดไปเองหรือหลอกตัวเอง แต่หลังจากลงตัวใหม่นี้
          แล้วมันรู้สึกอย่างนั้นจริงๆ การ์ดจอผมก็แค่ HD 5570 เอง ตอนแรกที่เล่น RAGE ไม่ได้ก็กะว่าจะลบทิ้งแล้วนะครับนั่น
          พูดถึงเกม RAGE นี้แล้ว ยิ่งถ้าลง Patch1 - Patch2 +ตัว Update ของ sKidRow ที่มีCrack ใหม่มาด้วยก็ยิ่งแหล่ม
          เล่นแล้วลื่นหัวทิ่มไม่ถึงกับแตก [แต่ถ้าดูหนังชมพู HD การ์ดจอผมทำได้ลื่นหัวแตกหลายๆรอบเลยละครับ]
