มาอีกแล้ว Forceware 258.49 WHQL
  • มาอีกแล้ว Forceware 258.49 WHQL
    Software Description
    This set of new drivers is tagged as Quadro driver (for NVIDIA's professional series graphics cards) however has support for common GeForce graphics cards.
    For full support including series 9, 200 and GTX 470 and 480 you can use a modded .inf file for that broad GeForce support.
    New in Release 258.49:
    Adds support for CUDA 3.1 for improved performance in GPU Computing applications. See CUDA for more details.
    Adds support for OpenGL 3.3
    ECC State (appeared in later Release 197 versions)
    New page for GPUs that support ECC (error correction code). The page lets you
    o Change the Error Correction Code (ECC) state for GPUs.
    o View GPU memory details.
    EDID Management
    Accessible from the View System Topology page, this feature lets you -
    o View the connector information
    o Get an EDID from a connected display and save it to disk
    o Force an EDID at a connector
    o Remove a forced EDID from a connector
    The SDI Capture page is now available with Windows Vista and Windows 7 drivers.
    Workstation application compatibility fixes. Please read the release notes for more information on product support, feature limitations, driver fixes and known compatibility issues.
    Existing Support:
    Support for the Open Computing Language (OpenCL) 1.0 in Quadro FX Series x700 and newer as well as the FX4600 and FX5600.
    Supports NVIDIA SLI technology (two-way SLI) for DirectX 9, DirectX 10, and OpenGL on SLI-certified Intel X58-based motherboard based system from select OEMs.
    Support for DDC-Ci/MCCS over the DisplayPort AUX channel.
    10-bits per color (10bpc) DisplayPort support for full-screen applications on supported products.
    แปลจากข้อความสีแดงด้านบน
    ไดรเวอร์ตัวนี้สำหรับการ์ด nVidia Quadro (for NVIDIA's professional series graphics cards)
    อย่างไรก็ตาม มันก็รองรับการ์ด GeForce ธรรมดาๆด้วย
    สำหรับการรองรับการ์ด series 9, 200 and GTX 470 and 480 จะต้องใช้ .inf ไฟล์ที่ mod แล้ว
    โหลดไฟล์ .inf ที่ mod แล้วได้ที่นี่
    Win 7 Vista 64Bit
    Win 7 Vista 32Bit
    โหลดไปลองก่อน ขอบคุณครับ
      หาของ XP ไม่เจอ มีแต่ของ Vista กับ 7
        ลองโหลดไปลอง win7 32 ลงไม่ได้
          มาอีก ละ --*
            ลงกับการ์ดอะไรครับ mod ไฟล์ .inf หรือยัง?
              series 8 ลงไม่ได้หรอ ?
                เท่าที่ดูจากไฟล์ inf แล้ว GF8xxx ลงได้นะครับ ลงได้ถึง GF6xxx เลย
                  น่าลองนะเนี่ย ฮ่าๆๆ
                    น่าสนใจดีครับ
                      ออกรายวัน
                        ของผม gts 250 1g ครับ
                          ลง 257.21 เมื่อวานเองออกใหม่อีกละ - -"
                            เหมือนจะทำเป็นรายปักษ์แล้วนะ
                              ผมเพิ่งลง 257.21 มาวันที่ 15/06/10 เอง ออกอิกแว้ว
