ไม่สิ เรียกว่า Preview Hotfix ละกัน
ATI Catalyst™ 10.4 Hotfix information and download
Last Updated
4/6/2010
Article Number
GPU-66
ATI Catalyst™ 10.4 Hotfix features:
The ATI Catalyst 10.4 Hotfix provides resolution for the following issue:
* Long load times for new maps in Battlefield: Bad Company 2 when using an ATI Radeon HD 5xxx series graphics card
Download:
In order to download and install the ATI Catalyst 10.4 Hotfix, click on the following link:
* Catalyst 10.4 Hotfix for Windows® 7 / Windows Vista 32-bit Edition
* Catalyst 10.4 Hotfix for Windows® 7 / Windows Vista 64-bit Edition
* Catalyst 10.4 Hotfix for Windows® XP Professional and Home Edition
* Catalyst 10.4 Hotfix for Windows® XP Professional x64 Edition
Note! This driver is provided as is and is not supported by AMD. It has not completed full AMD testing, and is only recommended for users experiencing the particular issue described above. This release is not supported by ATI Radeon™ HD5800 Eyefinity 6 series of products.
For detailed instructions on how to install the Hotfix, refer to:
* Article GPU-33 for a Windows 7 based system
* Article GPU-1 for a Windows Vista based system
* Article GPU-2 for a Windows XP / Windows 2000 based system
Additional Recommendations:
If the issue continues to occur after installation of the Hotfix, the following troubleshooting steps can help resolve the issue:
1. The problem may be a result of issues within the game application. Install any patches and / or updates available for the game application.
1. Contact the game developer for instructions on how to obtain / install the latest patches and / or updates for the game application
2. Conflict between the graphics card and motherboard’s BIOS version can cause performance issues. To reduce any hardware compatibility conflicts, install the latest BIOS version available for the motherboard
1. Contact the motherboard manufacturer for instructions on how to obtain / install the latest BIOS version for the motherboard
3. Installation errors that may have occurred during the installation of the game application may cause performance instability. Perform a clean install of the game application
1. First uninstall the application
2. Perform a fresh install of the application
3. Install any available patches / updates for the application
4. If the problem persists, reinstall the ATI Catalyst 10.3 Hotfix
4. Installation errors that may have occurred during the installation of the ATI Catalyst Software may cause performance instability. Perform a clean install of the ATI Catalyst Software
1. For detailed instructions on the recommended steps for uninstalling / installing ATI drivers, refer to:
1. Article GPU-33 for a Windows 7 based system
2. Article GPU-1 for a Windows Vista based system
3. Article GPU-2 for a Windows XP / Windows 2000 based system
Applicable Products:
This article applies to the following configuration(s):
* Hardware
o ATI Radeon™ HD 5xxx series of products
o ATI Radeon™ HD 4xxx series of products
* Software
o Battlefield: Bad Company 2
o City of Heroes (Beta Release)
* Operating System
o Windows® 7 32bit
o Windows® 7 64bit
o Windows® Vista 32 bit
o Windows® Vista 64 bit
Credit : http://support.amd.com/us/kbarticles...-4-Hotfix.aspx
Last Updated
4/6/2010
Article Number
GPU-66
Download:
* Hardware
* Software
* Operating System
o Windows® 7 32bit
o Windows® 7 64bit
