ปกติใช้ psu 500W ถ้าเพิ่ม 5770 อีกตัว ไม่ทราบว่าจะพอมั้ยครับ
สอบถาม 5770 CF
Recommended Power Supply
So here's my power supply recommendation:
Radeon HD 5770 (single GPU)
* The card requires you to have a 450 Watt power supply unit at minimum if you use it in a high-end system. That power supply needs to have (in total accumulated) at least 36 Amps available on the +12 volts rails.
Radeon HD 5770 CrossfireX (dual GPUs)
* A second card requires you to add another 108 Watts. You need a 600+ Watt power supply unit if you use it in a high-end system. That power supply needs to have (in total accumulated) at least 50 Amps available on the +12 volts rails.
