ATI Catalyst OpenGL 4.0 preview driver
  • ATI Catalyst OpenGL 4.0 preview driver
    Last Updated
    3/25/2010
    Article Number
    GPU-63
    ATI Catalyst OpenGL 4.0 preview driver:
    New Features:
    Fully supports the OpenGL 4.0 specification on the ATI Radeon HD 5000 Series.
    Fully supports the OpenGL 3.3 specification on the ATI Radeon HD Series & ATI FirePro Graphics Adapters.
    Instructions:
    Download and install the ATI Catalyst™ preview driver from the following location:
    โหลดจากลิงค์ข้างล่างนี้นะ
    ATI Catalyst OpenGL 4.0 preview driver for Windows® 7 / Windows® Vista
    ATI Catalyst OpenGL 4.0 preview driver for Windows® XP
    ATI Catalyst OpenGL 4.0 preview driver for Linux
    To properly install the ATI Catalyst ™ preview Driver, please use the following guide below for detailed instructions: ( 20870: Guide on how to install an ATI graphics card and / or its drivers )
    Note! This driver is provided as is and is not supported by AMD. It has not completed full AMD testing, and is only a preview driver.
    Applicable Products:
    This issue applies to the following configuration(s):
    * Hardware
    o ATI Radeon™ HD 5000 Series
    o ATI Radeon™ HD 4000 Series
    o ATI Radeon™ HD 3000 Series
    o ATI Radeon™ HD 2000 Series
    o ATI FirePro V8750
    o ATI FirePro V8700
    o ATI FirePro V8650
    o ATI FirePro V8600
    o ATI FirePro V7750
    o ATI FireGL V7700
    o ATI FireGL V7600
    o ATI FirePro V5700
    o ATI FirePro V5600
    o ATI FirePro V3750
    o ATI FirePro V3700
    o ATI FireGL V3600
    * Software
    o ATI Catalyst™ drivers
    * Operating System
    o Windows 7® 32bit
    o Windows 7® 64bit
    o Windows Vista® 32 bit
    o Windows Vista® 64 bit
    o Windows® XP
    o Windows® XP x64
    o Windows® XP Media Center
    o Linux
    Credit : http://support.amd.com/us/kbarticles...ew-driver.aspx
    มันยังไง หรอครับ
    คือ ช่วยเพิ่มอะไรหรอครับ
    มันคือ diver หรือว่าอะไรหรอครับ
    แล้วต้องลบ ไดเวอตัวเก่าไหมครับ
      The AMD Community is entering an exciting new phase—growing into a broader ecosystem of dedicated resources designed to better support and connect you.
        Opengl เป็น 4.0 ครับ ผมเทสไม่เป็นครับ
          แล้ว OpenGL ทำงานได้กับ ATI อย่างเดียวเหรอครับ
            ไม่แนใจครับ
            ตัวนี้มันลงรวมมากะ ไดเวอ ati เลยครับ
            เขียวก็ น่าจะมีมั่งครับ แต่จะเป็น 3.0
              ได้ทั้ง ATi และ Nvidia ครับ
              OpenGL 4.0 เพิ่งจะออกมาไม่นานนี้
              ทาง ATi เลยทำ Preview Driver มาให้ทดลองดูกัน
              ทาง Nvidia ก็ระบุไว้ว่าจะรองรับ OpenGL 4.0 ด้วยเช่นกัน
                Originally posted by birdoverclockzone View Post
                ไม่แนใจครับ
                มันไม่ใช้ Drive มันเป็นการเปิด OpenGL 4.0
                  มี 2000 series ด้วย
                    สรป ว่าไม่ใช่ diver หรอครับ
                    สะงั้น ผม ลบไดรืเวอ แล้ว ลง ตัวนี้ เพียวๆเลย
                      มันคือ Driver นั่นแล - -a
                        กดและดันไป
                          ตัวนี้คงไม่เกี่ยวข้องมองใจกับอะไรใช่เปล่าครับ
                          อย่างเช่น ลง 10.3 +SDK +ทำPhysX Nvidia MOD
                          ถ้าได้ลงตามข้างต้น ก็ให้ลงตัวนี้ตามทีหลัง ก็คงไม่ได้มีปัญหาอะไรเลยนะครับ
                            การ์ดนอกเหนือจากซีรี่ย์ 5000 ใช้ได้แค่ OpenGL 3.3 ตามที่เค้าบอกเลยครับ
                            อันนี้เป็น 4670 ลงแล้วได้แค่ OpenGL 3.3
                              ใช่เลย มันคือไดรเวอร์ +OpenGL 4.0 แต่ไม่รู้เป็นไดรเวอร์เวอร์ไหน น่าจะ 10.3
