ถ้าเอามาเป็นสเปคในร้านเล่นแต่เกมส์ออนไล ได้ไหมคับ
จะลดต้นทุนน่ะคับแบบว่าบางเกมเปิด 2จอคับ แล้ว (Intel® GMA 3100) เทียบเท่าตัวไหนที่เป็น pci 16x บ้างคับ
Model : (775-VSL) Asus P5G31D-M PRO
CPU : Intel Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium dual-core/Celeron dual-core/Celeron Processors
Support Intel 45nm CPU
Chipset : Intel G31 / ICH7
Front Side Bus : 1600(O.C)/1333/1066/800 MHz
Memory : 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
VGA : Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:75Hz
Expansion Slots1 x PCI Express x16
1x PCI Express x1
2x PCI Slots
Storage/RAID
1 xUltraDMA 100
4 xSATA 3 Gb/s ports
Audio : Realtek ALC887 8 -Channel High-Definition Audio CODEC
Lan : PCIe Gb LAN
USB : 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel)
Back Panel I/O Ports
1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
INTERNAL I/O
2 x USB connectors support additional 4 USB ports
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x CPU/ Chassis Fan connector
1 x High Definition front panel audio connector
1 x S/PDIF Out connector
1 x CD audio-in connector
1 x System panel connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
Form Factor : uATX Form Factor 9.6 inch x 8.6 inch ( 24.4 cm x 21.8 cm )
O/S Compatibility : XP/Vista
1x PCI Express x1
2x PCI Slots
Storage/RAID
1 xUltraDMA 100
Lan : PCIe Gb LAN
1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
INTERNAL I/O
1 x IDE connector
4 x SATA connectors
