NVIDIA 196.75 WHQL มาแล้วเด้อ
  • NVIDIA 196.75 WHQL มาแล้วเด้อ
    This is a WHQL-certified driver for GeForce 6, 7, 8, 9, 100, and 200-series desktop GPUs and ION desktop GPUs.
    New in Version 196.75
    * Adds support for Next Generation ION.
    * Adds support for GeForce GT 320, GeForce GT 330, and GeForce GT 340.
    * Upgrades PhysX System Software to version 9.10.0129.
    * Upgrades HD Audio driver to version 1.0.9.1 (for supported GPUs).
    * Increases performance in several PC games from v196.21 WHQL. The following are examples of measured improvements. Results will vary depending on your GPU and system configuration:
    o Up to 13% performance increase in Crysis: Warhead with a single GPU
    o Up to 30% performance increase in Crysis: Warhead with SLI technology
    o Up to 13% performance increase in H.A.W.X with single GPU
    o Up to 15% performance increase in H.A.W.X with SLI technology
    o Up to 30% performance increase in Left 4 Dead with single GPU
    o Up to 28% performance increase in Left 4 Dead with SLI technology
    * Adds SLI and multi-GPU support for top new gaming titles including Assassin Creed II, Battlefield: Bad Company 2, Command and Conquer 4: Tiberium Twilight, Grand Theft Auto IV: Episodes from Liberty City, Mass Effect 2, Napoleon: Total War, and Zombie Driver.
    * Enhanced SLI support for World of Warcraft and Unigine.
    * Adds override anti-aliasing support for Mass Effect 2.
    * Includes numerous bug fixes. Refer to the release notes on the documentation tab for information about the key bug fixes in this release.
    * Users without US English operating systems can select their language and download the International driver here.
    Existing Support:
    * Supports GPU-acceleration for smoother online HD videos with the new Adobe Flash 10.1 beta. Learn more here.
    * Supports OpenCL 1.0 (Open Computing Language) for all GeForce 8-series and later GPUs.
    * Supports OpenGL 3.2 for GeForce 8-series and later GPUs.
    * Supports CUDA Toolkit 3.0 features and performance enhancements. See CUDA Zone for more details.
    * Supports single GPU and NVIDIA SLI technology* on DirectX 9 and OpenGL.
    * Supports NVIDIA PhysX acceleration on a dedicated GeForce graphics card. Use one card for graphics and dedicate a different card for PhysX processing for game-changing physical effects. Learn more here.
    * Download these FREE PhysX and CUDA applications now!
    * Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
    *Note: The following SLI features are only supported on Windows Vista and Windows 7: Quad SLI technology using GeForce 9800 GX2 or GeForce GTX 295, 3-way SLI technology, Hybrid SLI, and SLI multi-monitor support.
    Enjoy NVIDIA content in your language.
    ขอบคุณมาก...
      แหล่มคร้าปปปป
        ใจจ้า
          Thank you
            พึ่ง Up 196.34 ไปได้ไม่กี่วัน *-*
                มาเมื่อวานตอนเย็นครับ เวอร์ชั่นนี้ เสถียรดีด้วยครับ
                ผมเลยจัดการดูดตั้งแต่เมื่อวานแล้ว อิอิ
                    เรียบร้อย ลงแล้วไม่มีปัญหาอะนะ
                    รอมานานเหลือเกิน เพราะเดือนที่แล้วไม่มีความคืบหน้าแต่อย่างใด
                    ซัพพอต ซีรี่ย์ 300 แปลว่ามันออกมาแล้วววว 555+
                      แบบนี้ไม่ลงได้ไง อิอิ
                        อีกไม่นานเกินรอ
                          ผมรู้สึกว่า Call of Duty Modern Warfare 2 กับ Battlefield Bad Company 2 ลื่นขึ้นเยอะเลยครับ
                            แบบนี้มันต้องถอน..(ตัวเก่าออก)
                              ใคมีปัญหาปรับสี video เเล้วไม่เห็นตัวเลขว่าปรับไปเท่าไหร่บ้างครับ
                              หรือเวอร์ชั่นใหม่ๆมันไม่เห็นเลขทีปรับเเล้ว
