* The card requires you to have a 500 Watt power supply unit at minimum if you use it in a high-end system. That power supply needs to have (in total accumulated) at least 40 Amps available on the +12 volts rails.
Radeon HD 5770 CrossfireX (dual GPUs)
* A second card requires you to add another 108 Watts. You need a 600+ Watt power supply unit if you use it in a high-end system. That power supply needs to have (in total accumulated) at least 55 Amps available on the +12 volts rails.
