อยากทราบราคา กาดจอรุ่นไหน ดีมีคุณภาพและถูก
  • อยากทราบราคา กาดจอรุ่นไหน ดีมีคุณภาพและถูก
    ใส่กับ MB gigabyte ep31-ds3l
    รูปครับ
    CPU Support for an Intel® Core™ 2 Extreme processor/ Intel® Core™ 2 Quad processor/ Intel® Core™ 2 Duo processor/ Intel Pentium processor Extreme Edition/ Intel® Pentium D processor/ Intel® Pentium 4 processor Extreme Edition/ Intel® Pentium 4 processor/ Intel® Celeron processor in the LGA 775 package
    Support for Intel Hyper-Threading Technology
    L2 cache varies with CPU
    Front Side Bus 1600(O.C.)/1333/1066/800 MHz FSB
    Chipset North Bridge: Intel® P31 Express Chipset
    South Bridge: Intel® ICH7
    Memory 4 x 1.8V DDR2 DIMM sockets supporting up to 4 GB of system memory (Note 1)
    Dual channel memory architecture
    Support for DDR2 1066/800/667 MHz memory modules (Note 2)
    * Because of chipset limitations, do not populate both DIMM sockets of the same channel (e.g. DDR and DDR2), or populate 4 DIMM sockets with double-sided memory modules to prevent system’s failure to start or incorrect detection of memory modules. Please refer to the user manual for the memory configurations table.
    * Because of chipset limitations, when using FSB 1333 MHz CPU with populating all DIMM sockets, memory frequency will be reduced from the original, and system instability or incorrect detection of memory module may be occur. Please refer “Memory Support List” for memory support information.
    (Note 1)Based on standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount. For example, 4 GB of memory size will instead be shown as 3.xx GB during system startup.
    (Note 2)Some memory configurations will result in memory frequency being reduced from the original frequency.
    Audio Realtek ALC888 codec
    High Definition Audio
    2/4/5.1/7.1-channel
    Support for S/PDIF In/Out
    Support for CD In
    LAN RTL 8111B chip (10/100/1000 Mbit)
    Expansion Slots 1 x PCI Express x16 slot
    3 x PCI Express x1 slots
    3 x PCI slots
    Storage Interface South Bridge:
    1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
    4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
    iTE IT8718 chip:
    1 x floppy disk drive connector supporting up to 1 floppy disk drive
    USB Integrated in the South Bridge
    Up to 8 USB 2.0/1.1 ports (4 on the back panel, 4 via the USB brackets connected to the internal USB headers)
    Internal I/O Connectors 1 x 24-pin ATX main power connector
    1 x 4-pin ATX 12V power connector
    1 x IDE connector
    1 x CPU fan header
    2 x system fan headers
    1 x power fan header
    1 x front panel header
    1 x front panel audio header
    1 x CD In connector
    1 x S/PDIF In header
    1 x S/PDIF Out header
    2 x USB 2.0/1.1 headers
    1 x chassis intrusion header
    1 x power LED header
    Back Panel Connectors 1 x PS/2 keyboard port Connectors
    1 x PS/2 mouse port
    1 x parallel port
    1 x serial port
    4 x USB 2.0/1.1 ports
    1 x RJ-45 port
    6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
    I/O Controller iTE IT8718 chip
    H/W Monitoring System voltage detection
    CPU/System temperature detection
    CPU/System/Power fan speed detection
    CPU overheating warning
    CPU/System/Power fan fail warning
    CPU fan speed control
    BIOS 1 x 4 Mbit flash
    Use of licensed AWARD BIOS
    PnP 1.0a, DMI 2.0, SM BIOS 2.3, ACPI 1.0b
    Unique Features Support for @BIOS
    Support for Download Center
    Support for Q-Flash
    Support for EasyTune (Note 3)
    Support for Xpress Install
    Support for Xpress Recovery2
    Support for Virtual Dual BIOS
    (Note 3)Available functions in Easytune may differ by motherboard model.
    Bundle Software Norton Internet Security (OEM version)
    Operating System Support for Microsoft®Windows Vista/XP/2000
    Form Factor ATX Form Factor; 30.5cm x 21.0cm
    Remark Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors’ website or 3rd party website.
    Due to most hardware/software vendors no longer offer support for Win9X/ME. If some vendors still has Win9X/ME drivers available, we will publish on website
    ตอนนี้ ผมชอบ ATi Radeon HD 4670 นะครับ แรงแถมถูกด้วย
    ยี่ห้อนี้ SAPPHIRE นะครับ การ์ด สวยดี
      PCIe 8400GS/512MB ECS (TD) 512MB DDR2 64-bit D-Sub S-Video DVI 990บาท ของใหม่มือ1
      ไม่น่ามีถูกกว่านี้ละ มีตัว960 เป็น 256M
          งบเท่าไหร่หว่า ถ้าประมาน 2000 หน่อย ๆ ก็ HD4670 ครับ
            ประมาน 3000 อ่าครับ ขอเเบบ ไม่ค่อยมีปันหา และไม่ร้อนอ่าคับ
              ส่วนมากเอามาเล่นเกมส์อ่า คับ
                hd4670
                9600gt
                เลือกเอา2ค่ายเลย ^^
                  แล้ว 9600 GT มีปันหาบ่อยรึป่าวครับ กลัวมาซ่อมบ่อยอะครับ
                    Winfast PX9500GT 512DDR3 เน้นๆ2พันกลาง-ปลายๆ
                      เพิ่มนิดครับ ถ้าเอา ประสิทธิภาพ/วัตต์ ตอนนี้ก็ยังคงเป็น 9600GT ครับ
                        9600 GTเนี่ยราคาประมานเท่าไรคับ เเล้วบอดผมรองรับไหมคับ
                          ดีมีคุณภาพและถูก
                          ดูแล้วไม่น่าจะมีไม่มี
                            รองรับครับ สำหรับการ์ดทุกตัวที่เป็น PCI-E รวมทั้ง9600GTนี้ด้วย
                            มือ1ขายกัน3พันนิดๆครับ
                            มือ2หาได้ตั้งแต่ราคา2300ยัน2650
                              ครับผม ขอบคุนมากครับผม
