5770 club
  • ขอบคุณครับ คุณต่อ สงสัยทาบางไปจริงๆ
    • Originally posted by LordPongpon View Post
      รู้สึกว่าจะมาแล้วนะ
      http://game.amd.com/us-en/drivers_ca...indows-7-32bit
      อันนี้คือไม่ใช้ ตัวเบต้าแล้วใช้ไหมครับ ใช้เบต้ามีปัญหามากมาย
      • คืนว่าผมสนใจรุ่น5770อยู่ แล้วผมใช้บอด์ P5Ql por CPU p4 3.0 จะใส่ด้วยกันได้ป่าวคับ
          ใส่ได้ครับ
          • Originally posted by berserkzo View Post
            ผมเล่นไม่เห็นจะตกอะไรเลย ลื่นปี๊ดๆๆๆๆ
            เอ้า 9.11 เพิ่มแค่นี้แหล่ะ ใครอ่านออกก็แปลมาบอกด้วยนะครับ
            - GPU Acceleration of H.264 video content using Adobe Flash Player 10.1 Beta – This release of supports the new Hardware Acceleration features of Adobe Flash Player 10.1 Beta for video encoded in the H.264 format. This feature is supported on the ATI Radeon HD 5800, ATI Radeon HD 5700 and ATI Radeon HD 4000 Series of products.
            - High Quality downscaling for video transcoding MSE – This release includes an enhancement for the ATI Video converter for users transcoding high quality interlaced content (1920×1080i @60i videos) down to small resolution progressive content, by maintaining high visual quality when down-scaling by a significant amount and converting interlaced video content to progressive.
            Resolved Issues for All Windows Operating Systems
            This section provides information on resolved issues in this release of the ATI Catalyst™
            Software Suite for Windows. These include:
            􀁺 Catalyst Control Center; Confirm/revert dialog now available when setting the
            Extend options for the display
            􀁺 Now able to enable and disable CrossFire when three displays are configured in
            extended mode
            􀁺 Catalyst Control Center no longer stops responding when setting Eyefinity SLS
            (Single Large Surface) mode for extended HDMI display
            Resolved Issues for the Windows 7 Operating System
            Software Suite for Windows 7. These include:
            􀁺 calMemCopy() no longer causes some systems with 2 ATI Radeon HD 3870 X2s
            to become unresponsive
            􀁺 Resolved, high bit rate audio from Blu-ray discs might not output when using
            PowerDVD 10
            􀁺 World in Conflict (DX10) no longer exhibits corruption when exiting from multiplayer
            game with extended desktop
            􀁺 resolved Tom Clancy's HAWX (in DX9 and DX10) no audio output during game
            play on some systems
            􀁺 Choppy video and audio no longer occurs when more than one digital audio
            source is enabled
            􀁺 Wolfenstein no longer stops responding when running in display mode of 2560 x
            1600
            􀁺 Resolved WinDVD Blu-ray playback will not start until application has been
            minimized and restored
            􀁺 WinDVD application now repaints and no longer remain on screen
            􀁺 Resolved display driver incompatibility with Resident Evil 5 Japanese release
            􀁺 Desktop is no longer cut short when 720P 60Hz HDTV custom mode is added in
            Windows 7 for some ASICs
            Resolved Issues for the Windows Vista Operating System
            Software Suite for Windows Vista. These include:
            􀁺 ANNO 1404 (also known as "Dawn of Discovery") no longer displays black
            texture corruption instead of surface terrain for some ASICs
            􀁺 A green line at the bottom when playing some interlaced content no longer
            occurs
            􀁺 Age of Conan does not show flashing corruption when played under CrossFire
            with medium or high settings
            􀁺 Video corruption no longer occurs when playing some H.264 video files under
            Cyberlink Power DVD
            􀁺 PowerDVD no longer intermittently terminates when playing HD MPEG2
            content in extended/clone mode
            􀁺 Supreme Commander no longer shows flickering on the primary display with
            extended desktop
            􀁺 Vista: Extended display are no longer disabled when CrossFire is enabled for the
            primary adapter
            􀁺 The de-noise value in the Avivo Video - Advanced Quality page is now set to the
            proper default value after driver installation
            􀁺 Crysis Warhead no longer stops responding when playing at very high settings
            with CrossFire enabled
            Resolved Issues for the Windows XP Operating System
            Software Suite for Windows XP. These include:
            􀁺 Transcoding of AC3 files no longer shows corruption in transcoded files
            􀁺 Battlefield 2142 running in CrossFire with "low" in-game settings no longer
            shows corruption on objects
            􀁺 Selection for "Add 720P 50Hz in the Display Manager (PAL)" no longer missing
            under HDTV Support in Catalyst Control Center
            More : http://www2.ati.com/relnotes/Catalys...ease_notes.pdf
            sigpic
            งดแรงชั่วคราว
            • เด่วลองหน่อยนะ โหลดเสดและ อิอิ ว่าแต่ไฟล์ 49 MB เองหรอครับ
              • Originally posted by TajabOn[G] View Post
                ใช่ครับ
                sigpic
                งดแรงชั่วคราว
                • อ่อ ลง 3อันเลยหรอพี่
                  ผมก็ว่า ทำไมเปิด CCC ไม่ได้
                    เปล่าครับ
                    อันที่สอง Driver Chipset อันที่สาม Driver AHCI
                    ของพี่ก็เป็นอ่ะ เลยลบของเก่าทิ้งให้หมดแล้วลงใหม่ ก็ไม่มีปัญหาอะไร
                    sigpic
                    งดแรงชั่วคราว
                    • พี่ต่อ ของพี่มี ขึ้นว่า Solution Problem ไหมอ่าครับ
                      • กำลังสนใจ 5770 ครับแต่กำลังสงสัยว่าถ้า 5770CF มันจะมีเกมไหนไหมที่ใช้รัน GPU ตัวเดียวอยู่ครับ
                        รอ non-ref อกก PWC ทำผิดหวัง ยอมเจ็บตัว4890เลยนะเนี่ยพึ่งถอยมา TwT
                          ไม่มีอ่ะ มีแต่ตอนนี้วินโด้เจ๊ง เมื่อคืนอากาศเย็นเลยอัดเครื่องดูเล่นๆ วินโด้เจ๊งเลย ซ่อมให้มันเข้ามาทำงานพอได้เท่านั้น
                          ถ้าไม่ได้เล่นความละเอียดจอสูงมาก ตัวเดียวผมว่ามันก็พอได้แล้วนะ
                          sigpic
                          งดแรงชั่วคราว
                          • ซ่อมวินโดว หรอครับ ทำยังไงอะพี่ *-*
                            • พี่ต่อ คราบ ผมเล่นนิสชิพ มันเด็งออก บอก เช็ค โซลูชั่น
                              ตอนแรกเล่นได้จน ปาไป 20 แล้วไม่เป็นไร
                              นึกจะเป็นก็เป็นเอา ดื้อๆ (ยังไม่ได้ OC 5770 OC แต่CPU )
                              ผมเลยตัดปัญหา ลงวินใหม่ Win 7 อะคราบ
                              แต่พอลง โปรแกรม OC 5770 ของAsus ตัวโปรแกรมก็เด้ง เช็คโซลูชั่น อีก
                              น่าจะต้องทำไงดี คราบ
                              รบกวนพี่ๆทุกท่านด้วยคราบ ขอบคุณคราบ
                              • Originally posted by tor_za View Post
                                จอ Dell 24" ครับท่านต่อ 1920*1080 โดยปกติมันจะร่วมกันประมวลผลใช่ไหมครับ
                                (เคยมีผ่านหูมาว่าบางทีมันใช้ตัวเดียวประมวลผลถ้าเปนอย่างนั้นผมคิดหนักแน่ๆ TwT)
