POWER 500w. (SATA) Extreme Tsunami 80Plus (Box,w/Cable)
About the product :
With safety certificate CE,FCC,CB,CSA,TUV,Nemko,BSMI,VDE
One 12 cm Fan for better cooliing effect
Bundled with Seria ATX connector
Dual + 12V output , support AMO K8 and
Intel LGA 775 motherboard
PCI Express connector available ,
support NVIDA SLI or ATI Crossfire
Features:
Excellent air flow design
High AMP Output
High working effciency>85%
Multi-Safety Standard complied
Over - Voltage Protection
Over - Current Protection
Short - Current Protection
Specification:
One 12 cm Fan
Thermal fan-speed control
Cooling fan design
Support Serial ATA Connector
With Mesh Sleeves for cabling
With rubber tube sleeves for cabling
With fine coating housing
With User manual
PCI E Connectors available
D Type Connector available x 6
Speedy Sata Connector x 2
PFC standard available (option)
ATX 12 V Version 2.20 power supply :
Dual + 12V out put
P1 (20+4 pins),4pin + 12 V
I/O switch
ใช้ PSU ตัวนี้พอไหวไหมคับ
