5 GOD OF GTX295
5 เทพ แห่ง จีทีเอ็กค์ 295 ที่ผมได้นำมาแนะนั้น ทั้ง อึด ทน แรง มีพลังมหาศาลเลยละ
เรามาแนะนำที่ละเทพก่อนเลยนะครับ
1.Point of Viwe Geforce GTX295
Specifications
Graphics Processing Unit GeForce GTX295 GPU Core
Graphics core speed 576 MHz
Memory 1792 MB
Memory type DDR3
Memory Speed 2016 MHz
Memory bus 896 bit
Shader processors 480
Shader clock 1242 MHz
DVI 2x
SPDIF
Interface PCI Express 2.0
Supplemental power connector 1x PCI-E 6-pins +1x PCI-E 8-pins
Cooling technique active
SLI 2-way
2.EVGA GeForce GTX 295 CO-OP Edition
Performance
NVIDIA GTX 295
576 MHz GPU
480 Processing Cores
400 MHz RAMDAC
Memory
1792 MB, 896 bit DDR3
2016 MHz (effective)
225.79 GB/s Memory Bandwidth
Interface
PCI-E 2.0 16x
DVI-I, DVI-I
SLI Capable
Resolution & Refresh
240Hz Max Refresh Rate
2048x1536 Max Analog
2560x1600 Max Digital
3.XFX Geforce GTX295
Bus Type
N/A PCI-E 2.0
Performance
N/A Standard
GPU Clock MHz
The main attributes of the GPU are the core clock rate, which typically ranges from 250 MHz to 1200 MHz in modern cards. 576 MHz
Shader Clock (MHz)
The number of pipelines (vertex and fragment shaders), which translate a 3D image characterized by vertices and lines into a 2D image formed by pixels. 1242 - 1246 MHz
Stream Processors
Through the use of stream processing, computer benefit from the ability to transparently access a large number of 'cores' (or, computational units) on a chip without having to separately manage each and every one of them along with their associated busses, memories, I/O, etc. 480
Memory Interface Bus (bit)
The bit data rate between memory and the GPU. 896
Memory Type
VRAM was typically based on DDR technology. During and after that year, manufacturers moved towards the vastly superior DDR2, GDDR3 and GDDR4. DDR3
Memory Size (MB)
the video card will have its own video memory which is called Video RAM or VRAM. The VRAM capacity of most modern video cards range from 128 MB to 2.0 GB. 1792 MB
Memory Clock (MHz)
The memory clock rate in modern cards are generally between 400 MHz and 2.4 GHz. 2000 - 2016 MHz
Output HDCP Capable
Designed to meet the output protection management (HDCP) and security specifications of the Blu-ray Disc and HD DVD formats, allowing the playback of encrypted movie content on PCs when connected to HDCP-compliant displays. Requires other HDCP-compatible components. 1 - 1
Microsoft® DirectX® Support
The standard for today's PCs and next-generation consoles enables stunning and complex effects for cinematic realism. NVIDIA GPUs offer the most complete implementation of the Shader Model feature set-including vertex texture fetch (VTF)-to ensure top-notch compatibility and performance for all DirectX applications. 10.0
Shader Model Support
Enables stunning and complex special effects. Next-generation shader architecture delivers faster and smoother gameplay. 4.0
Open GL Optimization and Support
Ensures top-notch compatibility and performance for OpenGL applications. 3.0
Minimum Power Requirement (Watt)
This is the minimum power supply wattage requirement for the graphics card to perform properly. 680W or greater system power supply (with a 12V current rating of 46A)
Cooling Fansink
Sometimes known as an active cooling device, a small electrical fan which drives air across a heat sink and as such will generate a small amount of noise. It is more effective than a heat sink alone at cooling. √
ROHS
The RoHS Directive stands for "the restriction of the use of certain hazardous substances in electrical and electronic equipment". This Directive bans the placing on the EU market of new electrical and electronic equipment containing more than agreed levels of lead, cadmium, mercury, hexavalent chromium, polybrominated biphenyl (PBB) and polybrominated diphenyl ether (PBDE) flame retardants. √
Profile
Some graphics cards have the capability to swap out the current bracket to make it compatible with low-profile computer systems that require a lower bracket card. Double, Standard
PhysX™ technology
NVIDIA's new GPU PhysX™ technology that renders convincing facial expressions, multiple ultra-high polygon characters in complex environments and convincing physical effects like weather and explosions. NVIDIA PhysX drivers are required to experience in-game GPU PhysX acceleration.
CUDA™ technology
NVIDIA CUDA™ technology and the new CUDA enables programmers to offload the most intensive processing tasks from their CPU to their GPU, putting the power of up to 240 multi-threaded processor cores to work for you.
SLI™ Technology
Delivers up to 2x the performance of a single GPU configuration for unequaled gaming experiences by allowing two graphics cards to run in parallel. The must-have feature for performance PCI Express® graphics, SLI dramatically scales performance on todays hottest games. √
Dimensions (Metric)
N/A 26.7 x 11.2 x 3.8
Max Resolution Analog
Maximum Screen Resolution indicates the maxiumum possible sharpness and clarity of an image that a monitor can display, measured in number of dots (pixels). 2048 x 1536
Max Resolution Digital
Maximum Screen Resolution indicates the maxiumum possible sharpness and clarity of an image that a monitor can display, measured in number of dots (pixels). 2560 x 1600
4.BFG NVIDIA GeForce GTX 295
Performance
GPU Dual NVIDIA® GeForce® GTX 295
Core Clock 576MHz
Shader Clock 1242MHz
Shader Model 4.0
Texture Fill Rate 92.2 Billion/sec. (Combined)
Processor Cores 480 (Combined)
Memory
Video Memory 1792MB (Combined)
Memory Type GDDR3
Memory Data Rate 1998MHz
Memory Interface 896-bit (Combined)
Memory Bandwidth 223.8GB/sec. (Combined)
5.PNY NVIDIA GeForce GTX 295
Product Specifications
Core Clock: 576 MHz
Processor Cores: 480
Processor Clock: 1242 MHz
Texture Fill Rate: 92.2 Billion/sec
On-board Frame Buffer: 1792MB
Memory Data Rate, effective: 2016 MHz
Memory Interface: 896-bit
Memory Bandwidth: 225.8 GB/sec.
On-board Outputs: DVI-I and DVI-I
Additional Outputs Supported: HDMI, VGA
Bus Type: PCI Express 2.0
เป็นไงละครับกับการ์ดจอเทพๆเหล่านี้ สเปคได้มาตรฐาน ต้องรอตัวที่ O/C ก่อนละ มันแน่
ข้อมูลทั้งนี้จากเว็บหลักของ POV,EVGA,XFX,BFG,PNY
THX Overclockzone.com
อันดับการ์ดจอที่แรงและคุ้มที่เชื่อถือได้
แต่!!!คนที่ใช้ GTS250 อย่ากดนะ "เพราะท่านได้พลาดไปแล้ว"
Specifications
Memory 1792 MB
Memory type DDR3
Memory bus 896 bit
DVI 2x
SPDIF
SLI 2-way
Performance
NVIDIA GTX 295
576 MHz GPU
400 MHz RAMDAC
Memory
Interface
PCI-E 2.0 16x
DVI-I, DVI-I
SLI Capable
Bus Type
N/A PCI-E 2.0
Performance
N/A Standard
GPU Clock MHz
Shader Clock (MHz)
Stream Processors
Memory Type
Memory Size (MB)
Memory Clock (MHz)
Output HDCP Capable
Cooling Fansink
ROHS
Profile
PhysX™ technology
CUDA™ technology
SLI™ Technology
Dimensions (Metric)
Performance
Core Clock 576MHz
Shader Model 4.0
Memory
Memory Type GDDR3
Core Clock: 576 MHz
