พอดีผมซื้อ การ์ดจอ HIS Radeon 2600 XT IceQ มาน่ะครับแล้วทีนี้สเปกเครื่องผมอยู่ที่
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD Athlon 64 X2 5000+
Codename Brisbane
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5000+
Package Socket AM2 (940)
CPUID F.B.2
Extended CPUID F.6B
Brand ID 4
Core Stepping BH-G2
Technology 65 nm
Core Speed 2654.3 MHz
Multiplier x FSB 13.0 x 204.2 MHz
HT Link speed 816.7 MHz
Stock frequency 2600 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Max FID 13.0x
Max VID 1.375 V
K8 Thermal sensor yes
K8 Revision ID 6.0
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Chipset
Northbridge ATI RS690/RS690M rev. 00
Southbridge ATI SB700 rev. 00
Memory Type DDR2
Memory Size 2048 MBytes
Channels Dual
Memory Frequency 379.2 MHz (CPU/7)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 18
Bank Cycle Time (tRC) 24
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) (0000000000000000)
Size 1024 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number
Number of banks 1
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-9-12 @ 200 MHz
JEDEC #2 4.0-4-4-12-16 @ 266 MHz
JEDEC #3 5.0-5-5-18-23 @ 400 MHz
หมายเหตุ : ที่ผมใช้ อยู่นี่คือ ออนบอร์ดนะครับ
ปัญหาคือ ผมเสียบการ์ดจอลงไปใน Slot ถูกต้องแล้ว แต่ตอนผมเปิดเครื่องไม่มีสัญญาณตอบรับ ไม่มีเสียง นิ่งไปเลยครับ แต่เวลาเอาการ์ดเก่ามาใส่ ก๊ใช้ได้ตามปกติ ผมลองลบ Driver อันเก่าแล้ว
ลองใส่ใหม่ก๊ไม่ได้ ครับ ขอคำแนะนำด้วยครับ
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processor 1 ID = 0
Codename Brisbane
CPUID F.B.2
Extended CPUID F.6B
Brand ID 4
Core Stepping BH-G2
Technology 65 nm
FID/VID Control yes
Max FID 13.0x
Max VID 1.375 V
K8 Revision ID 6.0
Chipset
Memory Type DDR2
Channels Dual
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Size 1024 MBytes
Part number
Number of banks 1
Data width 64 bits
Correction None
EPP no
XMP no
